War research. The mechanism of the direct nitrolysis of hexamine. .pdf 5.96MB PDF 318次下载 预览
War research. Kinetic studies on the conversion of D.P.T. and P.H.X. to H.M.X. .pdf 1.75MB PDF 181次下载 预览
Thermal decomposition of rossite and picrite in aqueous media B. Rate of transition of H.M.X. polymorphs. C. Thermochemistry of the R.D.X. reactions. (1).pdf 4.80MB PDF 298次下载 预览
The relation between RDX and HMX production in the Bachmann reaction..pdf 4.59MB PDF 199次下载 预览
The recovery of glacial acetic acid from the resi.pdf 8.83MB PDF 175次下载 预览
The reaction to form RDX from AN and praformaldehyde in AcO2.pdf 192.14KB PDF 126次下载 预览
The preparation of R.D.X. by the McGill process..pdf 5.20MB PDF 167次下载 预览
The preparation of 11Di 4chlorophenyl222trichloroethane DDT The role of hexamine dinitrate in the formation of RDX in the McGill or Ross reaction..pdf 3.36MB PDF 167次下载 预览
The nitration of polyamides..pdf 2.24MB PDF 166次下载 预览
The mechanism of RDX formation in the Bachmann re.pdf 12.45MB PDF 91次下载 预览
The chemistry of methyl bisBchloroethylamine and related compounds The deacidification of RDXB..pdf 9.17MB PDF 92次下载 预览
Studies on the conversion of PHX to AcAn..pdf 6.50MB PDF 145次下载 预览
Reactions of tetrahydrolinalool. The conversion of N.N. diethylaniline to N. ethylaniline. The preparation of picric acid by the oxynitration of benzene. The preparation of RDX..pdf 11.29MB PDF 80次下载 预览
Kinetic studies of the nitrolysis of hexamine in acetic acid and in chloroform and The detonation velocity of axially cavitated cylinders of cast dina. (1).pdf 9.54MB PDF 110次下载 预览
Effect of proknock substances on butane oxidation B.A study of the cyclonite reaction McGill process..pdf 4.81MB PDF 140次下载 预览
An investigation of the chemistry of some polymethylene nitramines..pdf 6.02MB PDF 48次下载 预览
A. Nickel impregnated respirator charcoals. B. An xray investigation of H.M.X. crystals. C. The kinetics of the reactions to produce R.D.X..pdf 11.36MB PDF 80次下载 预览
