Xilinx bit文件格式解析
warmonkey2023/03/05电子技术 IP:广东
注意这不是转载。
已经在Spartan 6, ZYNQ 7000, ZYNQ Ultrascale三个系列的器件上验证过。每个系列测试了1种器件。
提供文件解析代码。
The Xilinx .bit format is pretty simple. It uses keys and lengths to
divide the file.
Here is an example.  Below is a hex dump from the beginning of a .bit file:
00000000:  00 09 0f f0 0f f0 0f f0 0f f0 00 00 01 61 00 0a  .............a..
00000010:  78 66 6f 72 6d 2e 6e 63 64 00 62 00 0c 76 31 30  xform.ncd.b..v10
00000020:  30 30 65 66 67 38 36 30 00 63 00 0b 32 30 30 31  00efg860.c..2001
00000030:  2f 30 38 2f 31 30 00 64 00 09 30 36 3a 35 35 3a  /08/10.d..06:55:
00000040:  30 34 00 65 00 0c 28 18 ff ff ff ff aa 99 55 66  04.e..(.......Uf
Field 1
2 bytes          length 0x0009           (big endian)
9 bytes          some sort of header     0f f0 0f f0 0f f0 0f f0 00
Field 2
2 bytes          length 0x0001           (key-length-value below)
Field 3
1 byte           key 0x61                (The letter "a")
2 bytes          length 0x000a           (value depends on file name length)
10 bytes         string design name "xform.ncd" end with \0
Field 4
1 byte           key 0x62                (The letter "b")
2 bytes          length 0x000c           (value depends on part name length)
12 bytes         string part name "v1000efg860" end with \0
Field 4
1 byte           key 0x63                (The letter "c")
2 bytes          length 0x000b
11 bytes         string date "2001/08/10" end with \0
Field 5
1 byte           key 0x64                (The letter "d")
9 bytes          string time "06:55:04" end with \0
Field 6
1 byte           key 0x65                (The letter "e")
4 bytes          length 0x000c2818       (configuration length)
796696 bytes     raw bitstream starting with ffff ffff aa99 5566 sync word
//Xilinx .bit file header parser
class HeaderParser {
private:
    uint8_t state;
    //0=header len, 1=header data,
    //2=key, 3=length, 4=value,
    //5=bitstream len, 6=bitstream
    uint32_t len;
    uint8_t n;
    uint8_t key;
protected:
    virtual void parseKey(uint8_t k, char c) {
        qDebug() << "key" << (int)k << ":" << c;
public:
    bool done() {
        return (state == 6);
    void reset() {
        state = 0;
        n = 2;
    size_t bitstream_len() {
        if(state == 6) return len;
        else return 0;
    HeaderParser() {
        reset();
    void operator()(char x) {
        switch(state) {
        case 0: { //record header len
            len = (len << 8) | x;
            n--;
            if(n == 0) {
                n = len & 0x0000ffff;
                if(n == 0x0001) state = 2;  //go key-length-value mode
                else state = 1; //go bitstream len
        } break;
        case 1: //consume header data
            n--;
            if(n == 0) {
                n = 2;
                state = 0;
            break;
        case 2:   //parse key
            key = x;
            if(key == 0x65) {
                n = 4;
                state = 5;
            } else {
                n = 2;
                state = 3;
            break;
        case 3: { //record value len
            n--;
            if(n == 0) {
                state = 4;
        } break;
        case 4: { //consume value
            parseKey(key, x);
            n--;
            if(n == 0) state = 2;
        } break;
        case 5: { //record bitstream len
            n--;
            if(n == 0) state = 6; //bitstream len acquired
        case 6:
        default:;
[修改于 1年1个月前 - 2023/03/05 17:30:28]
zkf0100007
1年1个月前 IP:湖南
917943
学者 机友
2008/10/11注册,1时25分前活动
Cubesat
