改进了一下,
后面再考虑加上测距和陀螺仪模块
代码写得比较简单, 但效果做出来还可以。。。
配合着一个能跑python的win平板和一个热成像摄像头可以玩得不亦乐乎
不过就是电源的问题没解决, 解决了就可以户外了
用这段python代码就可以采集摄像头的数据了,我们接着要做的就是, 在上面画出十字和方框
import cv2 import numpy as np if __name__ == '__main__': cap = cv2.VideoCapture(url) while(True): ret, frame = cap.read() cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break cap.release() cv2.destroyAllWindows()
画的过程不难, 但是毕竟麻烦
话不多说, 直接放出来吧
import cv2 import numpy as np if __name__ == '__main__': img_count = 0 cap = cv2.VideoCapture('url') w = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH)) # float `width` h = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT)) # float `height` CROSS_W = int(w / 8) CROSS_H = int(h / 8) RETICLE_W_SIZE = int(w / 7) RETICLE_H_SIZE = int(w / 7) DELTA = 40 SHIFT = 40 DASH = 80 while(True): ret, frame = cap.read() text_color = (255,0,0) c1 = int(w/2) c2 = int(h/2) x1 = int(w/2 - CROSS_W/2) y1 = int(h/2) x11 = int(w/2 - CROSS_W/2 + DASH/2) y11 = int(h/2) x2 = int(w/2 + CROSS_W/2) y2 = int(h/2) x21 = int(w/2 + CROSS_W/2 - DASH/2) y21 = int(h/2) x3 = int(w/2) y3 = int(h/2 - CROSS_H/2) x31 = int(w/2) y31 = int(h/2 - CROSS_H/2 + DASH/2) x4 = int(w/2) y4 = int(h/2 + CROSS_H/2) x41 = int(w/2) y41 = int(h/2 + CROSS_H/2 - DASH/2) x5 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT) y5 = int(h/2 - RETICLE_H_SIZE/2) x51 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT) y51 = int(h/2 - RETICLE_H_SIZE/2 + DELTA) x52 = int(w/2 - RETICLE_W_SIZE/2 -SHIFT + DELTA) y52 = int(h/2 - RETICLE_H_SIZE/2) x6 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT) y6 = int(h/2 - RETICLE_H_SIZE/2) x61 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT) y61 = int(h/2 - RETICLE_H_SIZE/2 + DELTA) x62 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT - DELTA) y62 = int(h/2 - RETICLE_H_SIZE/2) x7 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT) y7 = int(h/2 + RETICLE_H_SIZE/2) x71 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT) y71 = int(h/2 + RETICLE_H_SIZE/2 - DELTA) x72 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT + DELTA) y72 = int(h/2 + RETICLE_H_SIZE/2) x8 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT) y8 = int(h/2 + RETICLE_H_SIZE/2) x81 = int(w/2 + RETICLE_W_SIZE/2 - SHIFT + DELTA) y81 = int(h/2 + RETICLE_H_SIZE/2) x82 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT) y82 = int(h/2 + RETICLE_H_SIZE/2 - DELTA) #cv2.line(frame,(x1,y1),(x2,y2),(255,255,255),1,cv2.LINE_AA) #cv2.line(frame,(x3,y3),(x4,y4),(255,255,255),1,cv2.LINE_AA) cv2.circle(frame, (c1,c2), radius=0, color=(255, 255, 255), thickness=-1) cv2.line(frame,(x1,y1),(x11,y11),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x2,y2),(x21,y21),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x3,y3),(x31,y31),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x4,y4),(x41,y41),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x5,y5),(x51,y51),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x5,y5),(x52,y52),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x6,y6),(x61,y61),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x6,y6),(x62,y62),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x7,y7),(x71,y71),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x7,y7),(x72,y72),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x8,y8),(x81,y81),(255,255,255),1,cv2.LINE_AA) cv2.line(frame,(x8,y8),(x82,y82),(255,255,255),1,cv2.LINE_AA) cv2.putText(frame,'Thermal IR',(64,64),cv2.FONT_HERSHEY_COMPLEX,1,(255,255,255),1,cv2.LINE_AA) cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('s'): cv2.imwrite("frame%d.jpg" % img_count, frame) img_count = img_count + 1 print("save one frame ok!") if cv2.waitKey(1) & 0xFF == ord('q'): break cap.release() cv2.destroyAllWindows()
如果你身边没有热成像摄像头, 用一般的摄像头也可以, 但是
这一行要换成自己的摄像头地址
[修改于 9个月15天前 - 2023/08/06 10:03:48]
