QT Arm Linux 面向搜索引擎编程 新手入门 问题一览
张静茹2019/08/16软件综合 IP:江苏
ARM 4418 开发板 使用 Ubuntu Mate系统
apt-get update 无法更新 安装软件 挂代理无效
更改/etc/apt/XXXXXXXXXXst
## Note, this file is written by cloud-init on first boot of an instance
## modifications made here will not survive a re-bundle.
## if you wish to make changes you can:
## a.) add 'apt_preserve_sources_list: true' to /etc/cloud/cloud.cfg
##     or do the same in user-data
## b.) add sources in /etc/apt/sources.list.d
## c.) make changes to template file /etc/cloud/templates/sources.list.tmpl
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial main restricted
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates main restricted
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial universe
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial multiverse
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial-security main restricted
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial-security main restricted
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial-security universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial-security universe
deb http://mirrors.ustc.edu.cn/ubuntu-ports xenial-security multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports xenial-security multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
# deb-src http://archive.canonical.com/ubuntu xenial partner
[修改于 4年8个月前 - 2019/08/31 17:00:33]
来自:计算机科学 / 软件综合
62
张静茹 作者
4年9个月前 修改于 4年9个月前 IP:江苏
862482
visual studio Linux 开发
新建工程 linux c 工程
添加 远程shh
在开发板中安装 g++ 编译环境
apt install g++
至此vs 可以远程生成了
开始调试
Microsoft Visual Studio
无法启动 gdb。系统中缺少 gdb,需进行安装,请使用系统的包管理器进行安装。
apt install  gdb
开始调试 产生
Segmentation fault
项目->属性->配置类型->改为"应用程序"
shows "Loading symbols for module /lib/XXXXXXXXXXXXXXXXX.3" and never finishes loading
解决方法:
Run "sudo apt-get install gdbserver" and change Debugging Mode to "gdbserver" in Visual Studio. You can find the Debugging Mode setting in Right Click on Project > Properties > Debugging
只需要 改Debugging Mode to "gdbserver 即可
XXXXXXXXXXXXXXXXXXXXXXXXX/questions/48394945/remote-debugging-on-raspberry
至此 VS 可以正常调试了
张静茹作者
4年9个月前 IP:江苏
862747
VisualGDB 编译调试QT
张静茹作者
4年9个月前 修改于 4年5个月前 IP:江苏
862782
 apt-get install qtbase5-dev qt5-default libqt5gui5 libqt5network5 libqt5printsupport5 libqt5widgets5 libqt5opengl5-dev libproxy1v5 libdevmapper1.02.1 watershed
arm开发板安装 qt开发环境
两个开发板的问题不一样,第二张3399开发板依然安装失败
最后好像是挂代理安装好的
只需要 apt-get install qtbase5-dev
2019-09-08
apt-get install qtbase5-dev qt5-default libqt5gui5 libqt5network5 libqt5printsupport5 libqt5widgets5 libqt5opengl5-dev libproxy1v5 libdevmapper1.02.1 watershed  libgles2-mesa-dev libegl1-mesa-dev qtbase5-dev-tools update-inetd libmirclient-dev libmircommon-dev libprotobuf-dev libprotobuf9v5
apt-get install qtbase5-dev qt5-default libqt5gui5 libqt5network5 libqt5printsupport5 libqt5widgets5 libqt5opengl5-dev libproxy1v5 libdevmapper1.02.1 watershed libgles2-mesa-dev qtbase5-dev-tools libegl1-mesa-dev update-inetd libmirclient-dev libmircommon-dev libprotobuf-dev libprotobuf9v5
apt-get install qtbase5-dev qt5-default qtbase5-dev-tools libgles2-mesa-dev libqt5gui5 libqt5network5 libqt5printsupport5 libqt5widgets5 libqt5opengl5-dev libegl1-mesa-dev libproxy1v5 gvfs-daemons libmirclient-dev watershed update-inetd systemd xserver-xorg-video-fbdev libmircommon-dev libprotobuf-dev libprotobuf9v5
才安装成功
apt-get install qtbase5-dev 5.9
可以指定版本
 又出现了 下面的问题
Infinite_Stalleris
4年8个月前 IP:青海
862882
茄子nb
张静茹作者
4年8个月前 IP:江苏
862891
root@firefly:~# apt-get install gdb
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 gdb : Depends: libbabeltrace1 (>= 1.2.1) but it is not going to be installed
       Recommends: libc-dbg
       Recommends: gdbserver but it is not going to be installed
 libgl1-mesa-dev : Depends: mesa-common-dev (= 19.0.8-0ubuntu0~18.04.1) but 18.2.8-0ubuntu0~18.04.2 is to be installed
                   Depends: libglvnd-dev but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
root@firefly:~# apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
  libglvnd-dev mesa-common-dev
The following NEW packages will be installed:
  libglvnd-dev
The following packages will be upgraded:
  mesa-common-dev
1 upgraded, 1 newly installed, 0 to remove and 191 not upgraded.
36 not fully installed or removed.
Need to get 0 B/606 kB of archives.
After this operation, 279 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 106038 files and directories currently installed.)
Preparing to unpack .../mesa-common-dev_19.0.8-0ubuntu0~18.04.1_XXXXXXXXb ...
Unpacking mesa-common-dev:arm64 (19.0.8-0ubuntu0~18.04.1) over (18.2.8-0ubuntu0~18.04.2) ...
dpkg: error processing archive /var/cache/apt/archives/mesa-common-dev_19.0.8-0ubuntu0~18.04.1_XXXXXXXXb (--unpack):
 trying to overwrite '/usr/include/KHR/khrplatform.h', which is also in package libmali-rk-dev:arm64 1.6-1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../libglvnd-dev_1.0.0-2ubuntu2.3_XXXXXXXXb ...
Unpacking libglvnd-dev:arm64 (1.0.0-2ubuntu2.3) ...
dpkg: error processing archive /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.3_XXXXXXXXb (--unpack):
 trying to overwrite '/usr/lib/aarch64-linux-gnu/XXXXXXXXX', which is also in package rockchip-mali-midgard14 1.6-1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@firefly:~#
解决方法
删除 /var/lib/dpkg/info 内的所有文件 重新执行apt --fix-broken install
张静茹作者
4年8个月前 修改于 4年8个月前 IP:江苏
862905
VisualGDB 创建的Qt工程 好像默认不支持Qml QT Quike
QQmlApplicationEngine 头文件找不到
Arm Linux 中找不到这个头文件
编辑D:\Project\QT\LinuxProject1\LinuxProject1\XXXXXXXXXXXXXXXXo
QT       += core gui
改为
QT       += quick
报错 Unknown module(s) in QT: quick
解决方法
XXXXXXXXXXXXXXXXXXXXt/hhhlizhao/article/details/73604445
apt-get install qtdeclarative5-dev
XXXXXXXXXXXXXXXXXXXXXXXXXXX/buster/qtdeclarative5-dev
XXXXXXXXXXXXXXXXXXXXXXXXXXX/buster/libqt5qml5
张静茹作者
862907
undefined reference to `QQmlApplicationEngine::QQmlApplicationEngine(QObject*)' LinuxProject1 D:\Project\QT\LinuxProject1\LinuxProject1\LinuxProject1.cpp 10
undefined reference to `QQmlApplicationEngine::objectCreated(QObject*, QUrl const&)' LinuxProject1 D:\Project\QT\LinuxProject1\LinuxProject1\LinuxProject1.cpp 12
undefined reference to `QQmlApplicationEngine::load(QUrl const&)' LinuxProject1 D:\Project\QT\LinuxProject1\LinuxProject1\LinuxProject1.cpp 20
undefined reference to `QQmlApplicationEngine::~QQmlApplicationEngine()' LinuxProject1 D:\Project\QT\LinuxProject1\LinuxProject1\LinuxProject1.cpp 10
undefined reference to `QQmlApplicationEngine::staticMetaObject' LinuxProject1 C:\Users\Game\AppData\Local\VisualGDB\RemoteSourceCache\192.168.1.104\0000\include\aarch64-linux-gnu\qt5\QtCore\qobject.h 339
ld returned 1 exit status LinuxProject1 D:\Project\QT\LinuxProject1\LinuxProject1\collect2 1
Command-line action failed LinuxProject1 D:\Project\QT\LinuxProject1\LinuxProject1\VisualGDB 1
原因 没有在pro文件指定 QT+=quick 找不到 lib 文件
张静茹作者
862918
root@firefly:/tmp/VisualGDB/d/Project/QT/LinuxProject1/LinuxProject1/Debug# ./LinuxProject1
QQmlApplicationEngine failed to load component
qrc:/main.qml:1 module "QtQuick" is not installed
qrc:/main.qml:2 module "QtQuick.Window" is not installed
XXXXXXXXXXXXXXXXXXXXX/questions/322356/qtquick-not-found-lubuntu
apt-get qtdeclarative5-qtquick2-plugin
张静茹作者
4年8个月前 IP:江苏
863190
variable `xxx' has initializer but incomplete type
出现这个错误字面意思是变量xxx定义了,但是不完整,
解决方法是,没有找到xxx变量的头文件,包含头文件即可解决
XXXXXXXXXXXXXXXXXXXXt/weixin_42445727/article/details/82594215
张静茹作者
4年8个月前 IP:江苏
863243
//Using QQmlComponent
//QQmlEngine engine;
//QQmlComponent component(&engine,
// QUrl::fromLocalFile("main.qml"));
//QObject *object = XXXXXXXXXXXXeate();
// delete object;
//qml 根对象 Window
QQuickView view(QUrl::fromLocalFile("main.qml"));
XXXXXXXow();
QObject *object = XXXXXXXotObject();
//object = XXXXXXXotContext();
//qml 根对象 Rectangle 或 Item
       //auto test_txt1 = object->findChild<QObject*>("test_text1");
//test_txt1->setProperty("text", "00000000");
 object->findChild<QObject*>("test_text1"); 返回null
解决方法 qml 中的 控件名要使用 objectName 而不是 id
Text {
        objectName:"test_text1" // 注意 必须使用 ""
        x: 292
        y: 271
        text: qsTr("Text")
        font.pixelSize: 28
张静茹作者
4年8个月前 IP:江苏
863244
XXXXXXXow();
 XXXXXXXotObject(); 返回null
QQuickView qml 根对象 Rectangle 或 Item
张静茹作者
4年8个月前 修改于 4年5个月前 IP:江苏
863546
使用sd卡的 开发板 烧写镜像后 系统剩余空间 16G的sd卡仅有几百兆 剩余空间
使用 fdisk /dev/mmcblk0 为sd卡 重新分区
root@Ubuntu-mate:~#  fdisk /dev/mmcblk0
Welcome to fdisk (util-linux 2.25.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): p
Disk /dev/mmcblk0: 14.9 GiB, 15931539456 bytes, 31116288 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00098996
Device         Boot  Start      End  Sectors  Size Id Type
/dev/mmcblk0p1        2048   133119   131072   64M 83 Linux
/dev/mmcblk0p2      133120 30000000 29866881 14.2G 83 Linux
输入d 2 删除第二个分区
输入n p 新建主分区 注意 要留个几百兆不要使用 sd卡可能会损坏 做镜像烧新卡的话镜像太慢 有可能 新卡写不进去
输入分区大小
w存盘 reboot重启
启动后 resize2fs  /dev/mmcblk0p2
reboot 再重启一下
df -h 查看磁盘剩余
张静茹作者
863555
这楼的 方法是错误的 删掉了
张静茹作者
4年8个月前 修改于 3年8个月前 IP:江苏
863580
需要安装的软件一览
gdb g++ make proxychina  proxychains
张静茹作者
4年8个月前 IP:江苏
863660
> main.cpp:8:19: fatal error: variant: No such file or directory
> compilation terminated.
> Makefile:167: recipe for target 'main.o' failed
> make: *** [main.o] Error 1
安装g ++ - 7; 例如,如果ubuntu
sudo add-apt-repository ppa:ubuntu-toolchain-r/test -y
sudo apt-get update
sudo apt-get install g++-7
add-apt-repository: command not found
解决方法
apt-get install software-properties-common python-software-properties
张静茹作者
4年8个月前 修改于 3年7个月前 IP:江苏
863661
qt 源码 build 方法
./configure -prefix /usr/local/Trolltech/Qt-5.12.4-arm/ -release -opensource -make libs -xplatform linux-g++-32 -optimized-qmake -pch -qt-libjpeg -qt-zlib -no-opengl -skip qt3d -skip qtcanvas3d -skip qtpurchasing -no-sse2 -no-openssl -no-cups -no-glib -no-iconv -nomake examples -nomake tools -skip qtvirtualkeyboard
实际测试:
./configure -prefix /usr/local/Trolltech/Qt-5.12.4-arm/ -opensource -no-opengl
qpaintervideosurface.cpp:67:12: error: invalid use of incomplete type 'class QGLContext'
     context->makeCurrent();
./configure -prefix /usr/local/Trolltech/Qt-5.12.4-arm/ -release -opensource -platform linux-g++ -make libs -optimized-qmake -pch -qt-libjpeg -qt-zlib -skip qt3d -skip qtcanvas3d -skip qtpurchasing -no-sse2 -no-openssl -no-cups -no-glib -no-iconv -nomake examples -nomake tools -skip qtvirtualkeyboard
去掉 -opengl 指定 -platform linux-g++
 -nomake docs -nomake examples -nomake demos -nomake tests
./configure -prefix /usr/local/Trolltech/Qt-5.12.4-arm/ -release -opensource -platform linux-g++ -nomake examples -nomake tests
交叉编译使用linux-arm-gnueabi-g++
make clean 清除编译
debian x86 安装 交叉编译器 apt-get install g++-arm-linux-gnueabihf
config 使用 平台 linux-arm-gnueabihf-g++
在 qtbase/mkspecs 中新建 linux-arm-gnueabihf-g++  编辑 XXXXXXXXnf 全部编译器改为 linux-arm-gnueabi-g++
查看文件格式
file sqlite3-shell.o
sqlite3-shell.o: ELF 64-bit LSB relocatable, x86-64, version 1 (SYSV), not stripped
 The OpenGL functionality tests failed!
解决方法 apt-get install libgl1-mesa-dev libglu1-mesa-dev
注意 安装完以后 删除全部qt源码重新解压 后 错误才会消失
../configure -prefix /usr/local/Trolltech/Qt-5.15.1-arm/ \
-release -opensource \
-platform linux-g++ -xplatform linux-arm-gnueabi-g++ \
-nomake examples -nomake tests -recheck-all
张静茹作者
4年8个月前 IP:江苏
863674
在编译Qt程序时出现如下报错
Qt error: one or more PCH files were found, but they were invalid
这是因为之前编译过程序,留下一些配置文件导致无法编译,清除之前的编译残留就行了
make distclean
张静茹作者
4年8个月前 IP:江苏
863681
qt 编译安卓的时候  产生
Command does not exist: C:\Microsoft\AndroidNDK64\android-ndk-r16b/toolchains/llvm/prebuilt/windows-x86_64/bin/llvm-strip.exe
更新 ndk 版本就好了
android-ndk-r16b 更新到 android-ndk-r20
张静茹作者
863868
linux 挂载移动硬盘
自动挂载到了 /media/fa/新加卷/
cd 不进去中文路径
fdisk -l 查看磁盘设备名
执行 umount /dev/sda1 卸载
mkdir /mnt/usb
mount -t /dev/sda1 /mnt/usb
张静茹作者
4年7个月前 修改于 3年9个月前 IP:江苏
864777
XXXXXXXXXXXXXXXXXXXXt/aristolto/article/details/77370853
  之前使用的是Qt4.7后来换成了Qt5.x,Qtcreator的版本使用4.0,使用中发现Qtcreator远程调试出现The selected build of GDB does not support Python scripting.It cannot be used in Qt Creator.
    意思是gdb不支持Python脚本不能再Qtcreator中使用。有问题问度娘找了半天终于发现一个能解决问题的分享一下:
    sudo apt-get install gdb-multiarch
   安装这个gdb工具。然后Qtcreator中Tools-->Options-->Build & Run 找到Debuggers选项卡添加/usr/bin/gdb-multiarch,对应的Kits中使用的gdb换成添加的这个。
    剩下的就是开启调试了。假设开发板的IP是192.168.1.123,虚拟机的IP是192.168.1.124。
1.登录到开发板telnet 192.168.1.123,
2.挂载nfs服务器 mount -t nfs  192.168.1.124:/nfsshare /mnt/nfs -o nolock,
3.然后gdbserver 192.168.1.124:8888 /mnt/nfs/yourapp -qws 回车,
4.最后Qtcreator中Debug菜单-->Start Debugging-->Attach to Running Debug Server
在弹出的窗口中kit选择自己配置的嵌入式的,
端口号8888,
Override Server Address:192.168.1.123,
Local executable:可执行文件在虚拟机中的位置
点击OK就可以正常调试了。
张静茹作者
4年7个月前 修改于 4年7个月前 IP:江苏
864781
Linux下C语言生成可执行文件的过程
在当前目录下创建一个C源文件并打开:
touch test.c
gedit test.c
直接编译:
 gcc test.c -o test
分步骤编译:
1) 预处理
    gcc -E test.c -o test.i
在当前目录下会多出一个预处理结果文件 test.i,打开 test.i 可以看到,在 test.c 的基础上把stdio.h和stdlib.h的内容插进去了。
2) 编译为汇编代码
    gcc -S test.i -o test.s
其中-S参数是在编译完成后退出,-o为指定文件名。
3) 汇编为目标文件
    gcc -c test.s -o test.o
.o就是目标文件。目标文件与可执行文件类似,都是机器能够识别的可执行代码,但是由于还没有链接,结构会稍有不同。
3) 链接并生成可执行文件
    gcc test.o -o test
readelf -h filename
查看可执行文件 elf 格式 arm x86 x64 等
张静茹作者
4年7个月前 修改于 4年6个月前 IP:江苏
864945
linux 挂载 img 文件
fdisk XXXXXXg
p
记录你想挂在的分区的start*512
mkdir /mnt/xxxx
mount -o loop,offset=start*512 XXXXXXg /mnt/xxxx
卸载 umount /mnt/xxxx
fuser -cu /mnt/xxxx
fuser -ck /mnt/xxxx
如果出现目标忙无法卸载
需要杀死占用的进程 卸载
NTFS U盘可能需要
fdisk -l 找到/dev/sd*
 mount -t ntfs /dev/sdb1 /mnt/sdb1
 mount /dev/sdb1 /mnt/sdb1
张静茹作者
865102
\etc\XXXXXXXXnf
/opt/Qt5.12.4_ARM_Linux/lib
修改 so文件搜索路径后要 ldconfig 刷新
添加 QT lib路径
link /opt/Qt5.12.4_ARM_Linux/lib 中的so文件到 /lib/ 下
ldd 查看 so 和 可执行文件 依赖
ll 软连接
 strings XXXXXXX.6 |grep GLIBC_
搜索XXXXXXX.6文件中 所有包含GLIBC_ 的 string
张静茹作者
865109
 ldd XXXXXXXXXXXXX.5
./XXXXXXXXXXXXX.5: /lib/arm-linux-gnueabihf/XXXXXXX.6: version `GLIBC_2.25' not found (required by ./XXXXXXXXXXXXX.5)
        XXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0x76af3000)
        XXXXXXXX.2 => /lib/arm-linux-gnueabihf/XXXXXXXX.2 (0x76ae0000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x769d2000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0x7695a000)
        libgcc_XXXX.1 => /lib/arm-linux-gnueabihf/libgcc_XXXX.1 (0x76932000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0x76845000)
        /lib/XXXXXXXXXXXXXXXXX.3 (0x76fcd000)
 ldd XXXXXXXXXXXXX.5 提示 XXXXXXX.6: version `GLIBC_2.25' not found
strings /lib64/XXXXXXX.6|grep GLIBC 查看 现在支持的版本
GLIBC_2.2.5
GLIBC_2.15
GLIBC_2.16
GLIBC_2.17
GLIBC_PRIVATE
解决方法
XXXXXXXXXXXXXXXXXX/pub/gnu/glibc/ 下载最新版本GLIBC
sudo apt-get install gawk
apt-get install bison
1. tar -xvf  glibc-2.18.tar.gz    解压
4. cd glibc-2.18
5. mkdir build;
6.  cd build
7. ../configure --prefix=/usr --disable-profile --enable-add-ons --with-headers=/usr/include
8. make -j4
9. make install
实测无用 装完了 系统崩了
张静茹作者
4年7个月前 IP:江苏
865217
错误XXXXXXXXXXXX.2:无法打开共享库文件:没有这样的文件或目录 #183
安装libgles2-mesa libgles2-mesa-dev
Video Acceleration Information (at the end)
Log Messages
[20744: 20744: 0505 / 151840.397379: ERROR: gl_XXXXXXXXXXXXXXXXX (292)]: Failed to load /usr/lib/chromium/swiftshader/XXXXXXXXXXXX: /usr/lib/chromium/swiftshader/XXXXXXXXXXXX: Can not open the shared object file: No file or folder of this type
GpuProcessHostUIShim: The GPU process exited with code 1024.
Solution:
find lib with:
ldconfig -p | grep libGLESv2
XXXXXXXXXXXX.2 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/XXXXXXXXXXXX.2
XXXXXXXXXXXX (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/XXXXXXXXXXXX
or with:
locate libGLESv2
/usr/lib/x86_64-linux-gnu/XXXXXXXXXXXX.2.0.0
/usr/lib/x86_64-linux-gnu/opera/XXXXXXXXXXXX
/usr/lib/x86_64-linux-gnu/opera/swiftshader/XXXXXXXXXXXX
Verification of the presence of the swiftshader folder
ls /usr/lib/chromium
(if the swiftshader folder does not exist)
sudo mkdir /usr/lib/chromium/swiftshader
then
sudo ln -s /usr/lib/x86_64-linux-gnu/libGLESv2.so /usr/lib/chromium/swiftshader/libGLESv2.so
sudo ln -s /usr/lib/x86_64-linux-gnu/libEGL.so /usr/lib/chromium/swiftshader/libEGL.so
finally
chrome://restart
张静茹作者
4年6个月前 修改于 4年6个月前 IP:江苏
865842
对比 4418 和 3399 apt 搜索qt 列表给phantom
确定开发板子是否支持 opengl
张静茹作者
4年6个月前 IP:江苏
865902
#!/bin/bash
# 获取要监控的本地服务器IP地址
IP=`ifconfig | grep inet | grep -vE 'inet6|127.0.0.1' | awk '{print $2}'`
echo "IP地址:"$IP
# 获取cpu总核数
cpu_num=`grep -c "model name" /proc/cpuinfo`
echo "cpu总核数:"$cpu_num
# 1、获取CPU利用率
#us 用户空间占用CPU百分比
#sy 内核空间占用CPU百分比
#ni 用户进程空间内改变过优先级的进程占用CPU百分比
#id 空闲CPU百分比
#wa 等待输入输出的CPU时间百分比
#hi 硬件中断
#si 软件中断
# 获取用户空间占用CPU百分比
cpu_user=`top -b -n 1 | grep Cpu | awk '{print $2}' | cut -f 1 -d "%"`
echo "用户空间占用CPU百分比:"$cpu_user
# 获取内核空间占用CPU百分比
cpu_system=`top -b -n 1 | grep Cpu | awk '{print $4}' | cut -f 1 -d "%"`
echo "内核空间占用CPU百分比:"$cpu_system
# 获取空闲CPU百分比
cpu_idle=`top -b -n 1 | grep Cpu | awk '{print $8}' | cut -f 1 -d "%"`
echo "空闲CPU百分比:"$cpu_idle
# 获取等待输入输出占CPU百分比
cpu_iowait=`top -b -n 1 | grep Cpu | awk '{print $10}' | cut -f 1 -d "%"`
echo "等待输入输出占CPU百分比:"$cpu_iowait
#2、获取CPU上下文切换和中断次数
# 获取CPU中断次数
cpu_interrupt=`vmstat -n 1 1 | sed -n 3p | awk '{print $11}'`
echo "CPU中断次数:"$cpu_interrupt
# 获取CPU上下文切换次数
cpu_context_switch=`vmstat -n 1 1 | sed -n 3p | awk '{print $12}'`
echo "CPU上下文切换次数:"$cpu_context_switch
#3、获取CPU负载信息
# 获取CPU15分钟前到现在的负载平均值
cpu_load_15min=`uptime | awk '{print $11}' | cut -f 1 -d ','`
echo "CPU 15分钟前到现在的负载平均值:"$cpu_load_15min
# 获取CPU5分钟前到现在的负载平均值
cpu_load_5min=`uptime | awk '{print $10}' | cut -f 1 -d ','`
echo "CPU 5分钟前到现在的负载平均值:"$cpu_load_5min
# 获取CPU1分钟前到现在的负载平均值
cpu_load_1min=`uptime | awk '{print $9}' | cut -f 1 -d ','`
echo "CPU 1分钟前到现在的负载平均值:"$cpu_load_1min
# 获取任务队列(就绪状态等待的进程数)
cpu_task_length=`vmstat -n 1 1 | sed -n 3p | awk '{print $1}'`
echo "CPU任务队列长度:"$cpu_task_length
#4、获取内存信息
# 获取物理内存总量
mem_total=`free | grep Mem | awk '{print $2}'`
echo "物理内存总量:"$mem_total
# 获取操作系统已使用内存总量
mem_sys_used=`free | grep Mem | awk '{print $3}'`
echo "已使用内存总量(操作系统):"$mem_sys_used
# 获取操作系统未使用内存总量
mem_sys_free=`free | grep Mem | awk '{print $4}'`
echo "剩余内存总量(操作系统):"$mem_sys_free
# 获取应用程序已使用的内存总量
mem_user_used=`free | sed -n 3p | awk '{print $3}'`
echo "已使用内存总量(应用程序):"$mem_user_used
# 获取应用程序未使用内存总量
mem_user_free=`free | sed -n 3p | awk '{print $4}'`
echo "剩余内存总量(应用程序):"$mem_user_free
# 获取交换分区总大小
mem_swap_total=`free | grep Swap | awk '{print $2}'`
echo "交换分区总大小:"$mem_swap_total
# 获取已使用交换分区大小
mem_swap_used=`free | grep Swap | awk '{print $3}'`
echo "已使用交换分区大小:"$mem_swap_used
# 获取剩余交换分区大小
mem_swap_free=`free | grep Swap | awk '{print $4}'`
echo "剩余交换分区大小:"$mem_swap_free
#5、获取磁盘I/O统计信息
echo "指定设备(/dev/sda)的统计信息"
# 每秒向设备发起的读请求次数
disk_sda_rs=`iostat -kx | grep sda| awk '{print $4}'`
echo "每秒向设备发起的读请求次数:"$disk_sda_rs
# 每秒向设备发起的写请求次数
disk_sda_ws=`iostat -kx | grep sda| awk '{print $5}'`
echo "每秒向设备发起的写请求次数:"$disk_sda_ws
# 向设备发起的I/O请求队列长度平均值
disk_sda_avgqu_sz=`iostat -kx | grep sda| awk '{print $9}'`
echo "向设备发起的I/O请求队列长度平均值"$disk_sda_avgqu_sz
# 每次向设备发起的I/O请求平均时间
disk_sda_await=`iostat -kx | grep sda| awk '{print $10}'`
echo "每次向设备发起的I/O请求平均时间:"$disk_sda_await
# 向设备发起的I/O服务时间均值
disk_sda_svctm=`iostat -kx | grep sda| awk '{print $11}'`
echo "向设备发起的I/O服务时间均值:"$disk_sda_svctm
# 向设备发起I/O请求的CPU时间百分占比
disk_sda_util=`iostat -kx | grep sda| awk '{print $12}'`
echo "向设备发起I/O请求的CPU时间百分占比:"$disk_sda_util
张静茹作者
4年5个月前 修改于 4年5个月前 IP:江苏
866757
3288 linux 系统 qt app依赖 与so路径 库位置
root@firefly:/opt/armapp# ldd armapp
./armapp: /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXX.5: version `Qt_5' not found (required by ./armapp)
./armapp: /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.5: version `Qt_5' not found (required by ./armapp)
        XXXXXXXXXXXXX.1 =>  (0xbec90000)
        XXXXXXXXXXXXXX.5 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.5 (0xb6d9d000)
        XXXXXXXXXXXX.5 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXX.5 (0xb6ab6000)
        XXXXXXXXXXXX.5 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXX.5 (0xb6829000)
        XXXXXXXXXXXXXXXX.5 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXXX.5 (0xb674c000)
        XXXXXXXXXXXXX.5 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.5 (0xb6404000)
        XXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0xb63e0000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0xb62d1000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0xb6259000)
        libgcc_XXXX.1 => /lib/arm-linux-gnueabihf/libgcc_XXXX.1 (0xb6231000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0xb6145000)
        XXXXXXXXXXXX.2 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXX.2 (0xb4e1f000)
        /lib/XXXXXXXXXXXXXXXXX.3 (0x7f61a000)
        XXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXX.0 (0xb4df6000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0xb4da7000)
        XXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXX.1 (0xb4d85000)
        XXXXXXXXXXXXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXXXXXXXXXX.1 (0xb4d67000)
        XXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.1 (0xb4d43000)
        XXXXXXXXXXXXX.55 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.55 (0xb4ba9000)
        XXXXXXXXXXX.55 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.55 (0xb4a8c000)
        XXXXXXXXXXXX.3 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXX.3 (0xb4a36000)
        XXXXXXXX.2 => /lib/arm-linux-gnueabihf/XXXXXXXX.2 (0xb4a23000)
        XXXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0xb494b000)
        XXXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXXX.1 (0xb4934000)
        XXXXXXXXX.2 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.2 (0xb4919000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0xb4828000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0xb4816000)
        XXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.1 (0xb47f2000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0xb47dd000)
        XXXXXXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.6 (0xb4766000)
        XXXXXXXXXXXXXXX.3 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXX.3 (0xb4740000)
        XXXXXXXXXXXXX.55 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.55 (0xb2e79000)
        XXXXXXXXXX.3 => /lib/arm-linux-gnueabihf/XXXXXXXXXX.3 (0xb2e1b000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0xb2e10000)
        XXXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.6 (0xb2dfc000)
 echo $LD_LIBRARY_PATH 为空
/etc/XXXXXXXXnf
include /etc/XXXXXXXXnf.d/*.conf
张静茹作者
4年5个月前 IP:江苏
866758
linux 设置so搜索路径
方法一:在配置文件/etc/XXXXXXXXnf中指定动态库搜索路径。
vi /etc/XXXXXXXXnf
添加 lib目录
ldconfig
方法二:通过环境变量LD_LIBRARY_PATH指定动态库搜索路径。
export LD_LIBRARY_PATH=”LD_LIBRARY_PATH:/opt/”
方法三:在编译目标代码时指定该程序的动态库搜索路径。
还可以在编译目标代码时指定程序的动态库搜索路径。通过gcc 的参数”-Wl,-rpath,”指定
张静茹作者
866783
张静茹作者
866784
XXXXXXXXXXXXXXXXXXXXXXX/p/9cc782436ece
QT移植
#!/bin/sh
##qt5.9.1-arm
export QT_ROOT=/opt/qt5.9.1-arm
export PATH=$QTDIR/bin:$PATH
export LD_LIBRARY_PATH=/lib:/usr/lib:/usr/local/lib:$QT_ROOT/lib
export QT_QPA_PLATFORM_PLUGIN_PATH=$QT_ROOT/plugins
export QT_QPA_PLATFORM=linuxfb:tty=/dev/fb0
export QT_QPA_FONTDIR=$QT_ROOT/lib/fonts
export QML2_IMPORT_PATH=$QT_ROOT/qml
export QT_QPA_PLATFORM=eglfs
export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=2
export QT_QPA_EGLFS_PHYSICAL_WIDTH=698             #根据你的显示器设置宽度,单位mm
export QT_QPA_EGLFS_PHYSICAL_HEIGHT=392           #根据你的显示器设置高度,单位mm
XXXXXXXXXXXXXXXXXXXXt/x356982611/article/details/71036775
设置环境变量
在~/.bashrc 中添加以下
export QTDIR=/usr
export QT_QPA_FONTDIR=$QTDIR/lib/fonts
export QT_QPA_PLATFORM_PLUGIN_PATH=$QTDIR/plugins/
export LD_LIBRARY_PATH=$QTDIR/lib:$LD_LIBRARY_PATH
export QML_IMPORT_PATH=
export QML2_IMPORT_PATH=$QTDIR/qml
export QT_QPA_PLATFORM=linuxfb:fb=/dev/fb0:size=800x600:mmSize=800x600:offset=0x0:tty=/dev/tty1
#export QT_QPA_EGLFS_FB="/dev/fb0"
#export QT_QPA_EGLFS_WIDTH=800
#export QT_QPA_EGLFS_HEIGHT=600
#export QT_QPA_EGLFS_DEPTH=32
#export QT_QPA_EGLFS_PHYSICAL_WIDTH=1920
#export QT_QPA_EGLFS_PHYSICAL_HEIGHT=1080
更新环境变量
souce ~/.bashrc
说明
在嵌入式Linux系统上有多个可以使用的平台插件:EGLFS,LinuxFB,KMS,DirectFB,Wayland。 这些可用性取决于Qt的配置。 在许多板上选择eglfs作为默认选项。 如果默认值不合适,则可以使用QT_QPA_PLATFORM环境变量参数来调用另一个插件。 或者可以使用” ./app.out -platfrom linuxfb “命令行。
参考
XXXXXXXXXXXXXXXXX/QtWayland
XXXXXXXXXXXXXXXX/qt-5/XXXXXXXXXXXXXXXXXml
张静茹作者
4年5个月前 IP:江苏
866792
apt-get install qml-module-qtquick-controls
Setting up qml-module-qtquick-layouts:armhf (5.9.5-0ubuntu1.1) ...
Setting up qml-module-qtquick-window2:armhf (5.9.5-0ubuntu1.1) ...
Setting up qml-module-qtgraphicaleffects:armhf (5.9.5-0ubuntu1) ...
Setting up qml-module-qtquick-controls:armhf (5.9.5-0ubuntu1) ...
张静茹作者
866796
 apt-get install libicu-dev
注意 glibc被升级了
XXXXXXXXXXXXXXXXXXXXXXXXX/questions/35840359/libicuuc-so-55-cannot-open-shared-object-file
 ./armapp: error while loading shared libraries: XXXXXXXXXXXXX.55: cannot open shared object file: No such file or directory
 ./armapp: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXX.5)
./armapp: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5)
./armapp: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXXXX.5)
./armapp: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXX.5)
./armapp: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXX.5)
        XXXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXX.5 (0x76c2d000)
        XXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5 (0x76844000)
        XXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5 (0x76544000)
        XXXXXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXXXX.5 (0x7641c000)
        XXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXX.5 (0x75fed000)
        XXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0x75fc4000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x75f0a000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0x75e95000)
        libgcc_XXXX.1 => /lib/arm-linux-gnueabihf/libgcc_XXXX.1 (0x75e6c000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0x75d7e000)
        /lib/XXXXXXXXXXXXXXXXX.3 (0x76f21000)
        XXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/mesa/XXXXXXXX.1 (0x75cfc000)
        XXXXXXXX.2 => /lib/arm-linux-gnueabihf/XXXXXXXX.2 (0x75ce9000)
        XXXXXXXXXXXXX.55 => not found
        XXXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0x75c13000)
        XXXXXXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXXXXXX.1 (0x75bea000)
        XXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.0 (0x75bac000)
        XXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXX.6 (0x75b91000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0x75b7f000)
        XXXXXXXXXXXX.3 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXX.3 (0x75b6b000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0x75b58000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0x75a6a000)
        XXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0x75a54000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0x75a49000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0x75a3f000)
        XXXXXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXXXX.0 (0x75a34000)
        XXXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.1 (0x75a28000)
        XXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.1 (0x75a0e000)
        XXXXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXX.1 (0x759fc000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0x759f0000)
        XXXXXXXXX.2 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.2 (0x759d6000)
        XXXXXXXXXX.3 => /lib/arm-linux-gnueabihf/XXXXXXXXXX.3 (0x7597a000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0x7596f000)
        XXXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.6 (0x75963000)
张静茹作者
4年5个月前 IP:江苏
866797
ldd XXXXXXXXXX
XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0x760cf000)
XXXXXXXXXXXXXXXXXXX.0 => not found
XXXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXX.0 (0x76092000)
apt-cache search libxkbcommon
libxkbcommon-dev - library interface to the XKB compiler - development files
libxkbcommon-x11-0 - library to create keymaps with the XKB X11 protocol
libxkbcommon-x11-dev - library to create keymaps with the XKB X11 protocol - development files
libxkbcommon0 - library interface to the XKB compiler - shared library
张静茹作者
866798
 apt-get install apt-file
apt-file update
apt-file search XXXXXXX.1
搜索 so 文件 在什么包中
root@Ubuntu-mate:/opt#
root@Ubuntu-mate:/opt# ./LinuxArmQtGuiApp
QML debugging is enabled. Only use this in a safe environment.
XXXXXXXXXugin: Could not load the Qt platform plugin "xcb" in "/opt/Qt5.12.4_ARM_Linux/plugins" This application failed to start because no Qt platform plugin could be initialized. Reinstalli
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, webgl, xcb
Aborted (core dumped)
root@Ubuntu-mate:/opt# ^C
root@Ubuntu-mate:/opt# export QT_DEBUG_PLUGINS=1
QFactoryLoader::QFactoryLoader() checking directory path "/opt/Qt5.12.4_ARM_Linux/plugins" ...
QFactoryLoader::QFactoryLoader() checking directory path "/opt" ...
QFactoryLoader::QFactoryLoader() looking at "/opt/LinuxArmQtGuiApp"
"Failed to extract plugin meta data from '/opt/LinuxArmQtGuiApp'"
         not a plugin
QFactoryLoader::QFactoryLoader() looking at "/opt/qt-everywhere-src-5.12.4-compile-completed.tar"
QElfParser: '/opt/qt-everywhere-src-5.12.4-compile-completed.tar' is not an ELF object
"'/opt/qt-everywhere-src-5.12.4-compile-completed.tar' is not an ELF object"
         not a plugin
QFactoryLoader::QFactoryLoader() looking at "/opt/QT_5.12.4_ARM_Linux_in_opt.tar"
QElfParser: '/opt/QT_5.12.4_ARM_Linux_in_opt.tar' is not an ELF object
"'/opt/QT_5.12.4_ARM_Linux_in_opt.tar' is not an ELF object"
         not a plugin
QFactoryLoader::QFactoryLoader() checking directory path "/opt/Qt5.12.4_ARM_Linux/plugins/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXX"
Found metadata in lib /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXX, metadata=
    "IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
    "MetaData": {
        "Keys": [
            "eglfs"
    "archreq": 0,
    "className": "QEglFSIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("eglfs")
QFactoryLoader::QFactoryLoader() looking at "/opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXXXX"
Found metadata in lib /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXXXX, metadata=
    "MetaData": {
        "Keys": [
            "linuxfb"
    "archreq": 0,
    "className": "QLinuxFbIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("linuxfb")
    "MetaData": {
        "Keys": [
            "minimal"
    "archreq": 0,
    "className": "QMinimalIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXXXXXXX"
Found metadata in lib /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXXXXXXX, metadata=
    "MetaData": {
        "Keys": [
            "minimalegl"
    "archreq": 0,
    "className": "QMinimalEglIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("minimalegl")
QFactoryLoader::QFactoryLoader() looking at "/opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXXXXXX"
Found metadata in lib /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXXXXXXXX, metadata=
    "MetaData": {
        "Keys": [
            "offscreen"
    "archreq": 0,
    "className": "QOffscreenIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXX"
Found metadata in lib /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXX, metadata=
    "MetaData": {
        "Keys": [
            "vnc"
    "archreq": 0,
    "className": "QVncIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("vnc")
    "MetaData": {
        "Keys": [
            "webgl"
    "archreq": 0,
    "className": "QWebGLIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("webgl")
    "MetaData": {
        "Keys": [
            "xcb"
    "archreq": 0,
    "className": "QXcbIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("xcb")
QFactoryLoader::QFactoryLoader() checking directory path "/opt/platforms" ...
Cannot load library /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXX: (XXXXXXXXXXXXXXXXXXX.0: cannot open shared object file: No such file or directory)
QLibraryPrivate::loadPlugin failed on "/opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXX" : "Cannot load library /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXX: (XXXXXXXXXXXXXXXXXXX.0: cannot open shared object file: No such file or directory)"
XXXXXXXXXugin: Could not load the Qt platform plugin "xcb" in "/opt/Qt5.12.4_ARM_Linux/plugins" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, webgl, xcb.
root@Ubuntu-mate:/opt# ldd /opt/Qt5.12.4_ARM_Linux/plugins/platforms/XXXXXXXXXX
        XXXXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXXX.5 (0x76e67000)
        XXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5 (0x76a7e000)
        XXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXX.5 (0x7664f000)
        XXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.1 (0x76620000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x76512000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0x76425000)
        /lib/XXXXXXXXXXXXXXXXX.3 (0x76f8b000)
        XXXXXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXXX.1 (0x763e8000)
        XXXXXXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.6 (0x76384000)
        XXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXX.5 (0x76325000)
        XXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0x76301000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0x762ee000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0x762d7000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0x761e9000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0x76171000)
        XXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXX.6 (0x7615b000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0x76139000)
        XXXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXX.0 (0x760fa000)
        XXXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0x76024000)
        libgcc_XXXX.1 => /lib/arm-linux-gnueabihf/libgcc_XXXX.1 (0x75ffc000)
        XXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/mesa/XXXXXXXX.1 (0x75f7a000)
        XXXXXXXXXXXXX.55 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.55 (0x75de1000)
        XXXXXXXXXXX.55 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.55 (0x75cc4000)
        XXXXXXXX.2 => /lib/arm-linux-gnueabihf/XXXXXXXX.2 (0x75cb1000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0x75ca6000)
        XXXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.6 (0x75c99000)
        XXXXXXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXXXXXX.1 (0x75c71000)
        XXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXX.1 (0x75c4f000)
        XXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXX.0 (0x75c27000)
        XXXXXXXXXXXX.3 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXX.3 (0x75be8000)
        XXXXXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXXXXX.1 (0x75bd3000)
        XXXXXXXXXX.3 => /lib/arm-linux-gnueabihf/XXXXXXXXXX.3 (0x75b77000)
        XXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.0 (0x75b39000)
        XXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXX.6 (0x75b1e000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0x75b0c000)
        XXXXXXXXXXXX.3 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXX.3 (0x75af7000)
        XXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0x75ae1000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0x75ad6000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0x75acc000)
        XXXXXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXXXX.0 (0x75ac2000)
        XXXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.1 (0x75ab5000)
        XXXXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXX.1 (0x75aa3000)
        XXXXXXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.1 (0x75a97000)
        XXXXXXXXX.2 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.2 (0x75a7e000)
        XXXXXXXXXXXXX.55 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.55 (0x741b7000)
        XXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0x7418c000)
        XXXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXXX.1 (0x74176000)
        XXXXXXXXXX.5 => /lib/arm-linux-gnueabihf/XXXXXXXXXX.5 (0x74156000)
        XXXXXXXXXXXX.20 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXX.20 (0x740c7000)
        XXXXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXX.0 (0x740ab000)
apt-get install libxkbcommon-dev libxkbcommon-x11-dev
Got keys from plugin meta data ("xcb_glx")
QFactoryLoader::QFactoryLoader() checking directory path "/opt/xcbglintegrations" ...
loaded library "/opt/Qt5.12.4_ARM_Linux/plugins/xcbglintegrations/XXXXXXXXXXXXXXXXXXXXXXXXXX"
./LinuxArmQtGuiApp: symbol lookup error: /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXXX.5: undefined symbol: FT_Get_Font_Format
apt-get install libfreetype6
张静茹作者
866812
root@FriendlyARM:/opt/armapp# ./armapp
main()
app(argc, argv)
 QObject::connect()
./armapp: symbol lookup error: /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXXX.5: undefined symbol: FT_Get_Font_Format
root@FriendlyARM:/opt/armapp# XXXXXXXXXXXXXXX.5: undefined symbol: FT_Get_Font_Format
XXXXXXXXXXXXXXX.5:: command not found
root@FriendlyARM:/opt/armapp# apt-cache search libfreetype
libfreetype6 - FreeType 2 font engine, shared library files
libfreetype6-dev - FreeType 2 font engine, development files
libgd-perl - Perl module wrapper for libgd
libcoin80v5 - high-level 3D graphics kit implementing the Open Inventor API
root@FriendlyARM:/opt/armapp# apt-get install libfreetype6
XXXXXXXXXXXXXXXXXXXXXXXXX/questions/56039011/how-to-solve-a-symbol-look-up-error-on-qt-installation-on-ubuntu
张静茹作者
866813
至此 所有问题都解决了,linux arm app 跑起来了
张静茹作者
4年5个月前 IP:江苏
866851
XXXXXXXXXXXXXXXXXXXXXXXXX/questions/18648257/how-to-implement-wpf-like-mvvm-in-qt-c-qml
How to implement WPF-like MVVM in Qt/C++/QML?
Ask Question
Asked 6 years, 2 months ago
Active 2 years, 7 months ago
Viewed 13k times
I'm writing a proof of concept application, that is very simple. Basically it's composed of a UI where a list of "Note" type objects is displayed in a QML ListView.
I then have a few classes which is something along the lines:
#ifndef NOTE_H
#define NOTE_H
#include <string>
using namespace std;
class Note
public:
    Note(QObject* parent = 0)
        : QObject(parent)
    Note(const int id, const string& text)
        : _id(id), _text(text)
    int id()
        return _id;
    const string text()
        return _text;
    void setText(string newText)
        _text = newText;
private:
    int _id;
    string _text;
#endif // NOTE_H</string>
Then a repository:
class NoteRepository : public Repository<note>
public:
    NoteRepository();
    ~NoteRepository();
    virtual shared_ptr<note> getOne(const int id);
    virtual const unique_ptr<vector<note>> getAll();
    virtual void add(shared_ptr<note> item);
private:
    map<int, shared_ptr<note>> _cachedObjects;
};</int, shared_ptr<note></note></vector<note></note></note>
Finally a ViewModel that exposes Note to QML
class MainViewModel : public QObject
    Q_OBJECT
    Q_PROPERTY(QQmlListProperty<note> notes READ notes NOTIFY notesChanged)
    Q_PROPERTY(int count READ count() NOTIFY countChanged)
public:
    MainViewModel(QObject *newParent = 0);
    int count();
    QQmlListProperty<note> notes();
signals:
    void notesChanged();
    void countChanged();
public slots:
private:
    std::shared_ptr<unitofwork> _unitOfWork;
    static void appendNote(QQmlListProperty<note> *list, Note *note);
    QList<note*> _notes;
};</note*></note></unitofwork></note></note>
PLEASE DON'T MIND ANY C++ MISTAKES HERE and mind they are incomplete, it's not the point at this moment as I'm constantly adapting this as I learn.
The point where I'm struggling is, how to expose a list-like object to QML? The requirement is this list must be dynamic, one should be able to add, delete and modify the text of a note. When the list is modified by C++, it should also notify the UI (signal).
I tried QQmlListProperty, but couldn't figure a way of exposing it to QML. Then I read on another SO post this type can't be modified by QML (??), and I stumbled upon QAbstractItemModel.
Anyhow, can anyone point me to the right direction?
johnildergleidisson
1,85933 gold badges2727 silver badges4545 bronze badges
add a comment
1 Answer
activeoldestvotes
I've posted a rather complete example in another answer.
The general procedure is:
  1. Create a model that derives from QAbstractItemModel. You can reuse any of the models already provided by Qt, for example QStringListModel.
  2. Expose it to QML. E.g. use setContextProperty() of QML Engine's rootContext().
  3. The model's roles are visible in the context of the delegate in QML. Qt provides default mapping between names and roles for the DisplayRole (display) and EditRole (edit) in a default implementation of roleNames().
    delegate: Component {
        TextInput {
            width: view.width // assuming that view is the id of the view object
            text: edit // "edit" role of the model, to break the binding loop
            onTextChanged: model.display = text // "display" role of the model
  4. You can create intermediate viewmodels, if needed, by attaching proxy models between the views and the backend models. You can derive from QAbstractProxyModel or one of its subclasses.
张静茹作者
4年5个月前 IP:江苏
866969
./LinuxArmQtGuiApp -platform linuxfb 以linuxfb 启动 应用程序
张静茹作者
867046
# See XXXXXXXXXXXXXXXXXXXXXX/community/UpgradeNotes for how to upgrade to
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic main restricted
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic main restricted
## distribution.
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-updates main restricted
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-updates main restricted
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic universe
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic universe
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-updates universe
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-updates universe
## security team.
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic multiverse
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic multiverse
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-updates multiverse
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-updates multiverse
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-backports main restricted universe multiverse
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-backports main restricted universe multiverse
deb XXXXXXXXXXXXXXXXXXXXXXXXXXXX/ubuntu bionic partner
deb-src XXXXXXXXXXXXXXXXXXXXXXXXXXXX/ubuntu bionic partner
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-security main restricted
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-security main restricted
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-security universe
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-security universe
deb XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-security multiverse
deb-src XXXXXXXXXXXXXXXXXXXXXXX/ubuntu-ports/ bionic-security multiverse
deb XXXXXXXXXXXXXXXXXXXXXt/debian/ stretch main contrib non-free
deb-src XXXXXXXXXXXXXXXXXXXXXt/debian/ stretch main contrib non-free
deb XXXXXXXXXXXXXXXXXXXXXXXXXX/ stretch/updates main contrib non-free
deb-src XXXXXXXXXXXXXXXXXXXXXXXXXX/ stretch/updates main contrib non-free
deb XXXXXXXXXXXXXXXXXXXXXt/debian/ stretch-updates main contrib non-free
deb-src XXXXXXXXXXXXXXXXXXXXXt/debian/ stretch-updates main contrib non-free
deb XXXXXXXXXXXXXXXXXXXXXXXX/debian stretch main
XXXXXXXXXXXXXXXXXXXXXXXXXXX/repogen/
中科大 XXXXXXXXXXst 生成器
XXXXXXXXXXXXXXXXXXXXXXXXXX/help/XXXXXXXXXml
张静茹作者
4年5个月前 IP:江苏
867048
张静茹作者
4年5个月前 IP:江苏
867096
debian 系统解压xz文件失败
tar (child): xz: Cannot exec: No such file or directory
tar (child): Error is not recoverable: exiting now
apt-get install bzip2
apt install -y xz-utils
张静茹作者
867144
U盘被写保护在本电脑,但在别的电脑又可以写入怎么解除
2019-04-01 09:52 来源: 本站整理 作者:电脑爱好者 浏览量:17410次
    不知道大家有没有遇到过,U盘在自己的电脑上提示写保护,不能写入数据,只能读取,但把U盘插其他电脑又可以读写数据。其实这种情况一般都可以排除U盘本身的问题,问题的关键在你自己的电脑系统上面,如果你直接重装系统那么就不用看了,下面就教大家如何解决系统导致的U盘被写保护怎么解除的问题,在不重装的情况下。
  方法一、修改注册表的方式来解除写保护
  “Win+R”组合键后输入“regedit”进入注册表编辑器,(也可以在开始-运行里输入CMD然后输入regedit)定位到
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
新建“项”,命名为“StorageDevicePolicies”,如果有了直接双击进入。
然后在新建“项“下新建“DWORD(32位)值”,命名为”WriteProtect“,并双击修改”数值数据“为0。
  然后以管理员的身份运行命令提示符(就是之前说的开始-运行-cmd后的命令界面),执行“diskpart”。
  等进入diskpart后运行“list disk”可以看到电脑上的磁盘列表,根据容量大家自己判断下哪个是外接的U盘。
然后执行下面的命令选取U盘:
select disk n(n指代U盘序号,从上图列表中确定,本文示例选1)
接下来只要输入
attributes disk clear readonly
就可以解除该U盘的“写保护”状态。
方法二、如果还不行,看看这个系统路径下C:\Windows\System32\drivers,有没有一个名为XXXXXXXs的文件,如果有的话,删除重启就行了。没有的话也别心急,继续往下看:
  regedit命令直接进入注册表,定位到
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\usbehci
项目后,查看右侧“start”的数值数据,如果不是默认的“3”,而是“2”或者“4”改回来,重启电脑。
方法三、以上这些都不行的话,可以利用第3方工具来解决。推荐并下载大势至电脑文件防泄密系统,它功能有点多,主要是防止它人盗取数据,这里只需要用它某一项功能,就可以彻底解除U盘被写保护锁定的状态。
  打开软件后,照上图先选择“恢复USB存储设备、手机或蓝牙等设备的使用”,然后再选择同在一个红框中的“可以从电脑向U盘拷贝资料,但必须输入管理员密码”,输入软件默认的“123”密码后再看U盘是否已经不在提示写保护了呢。
  所以系统导致的U盘被写保护,主要就是对系统本身进行修改,当然你也可以重装一下系统,绝对是可以解决的,但装系统很麻烦又要从新打补丁,上面的方法一般都是可以解决的。
张静茹作者
4年5个月前 IP:江苏
867517
root@bpi-iot-ros-ai:/opt# ldd QmlProjectTemplate
        XXXXXXXXXXXXX.1 (0xbee23000)
        XXXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXX.5 (0xb6c5d000)
        XXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5 (0xb6874000)
        XXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5 (0xb6574000)
        XXXXXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXXXX.5 (0xb644c000)
        XXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXX.5 (0xb601d000)
        XXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0xb5fe7000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0xb5edc000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0xb5e61000)
        libgcc_XXXX.1 => /lib/arm-linux-gnueabihf/libgcc_XXXX.1 (0xb5e38000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0xb5d3e000)
        /lib/XXXXXXXXXXXXXXXXX.3 (0xb6f4e000)
        XXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXX.1 (0xb5cbc000)
        XXXXXXXX.2 => /lib/arm-linux-gnueabihf/XXXXXXXX.2 (0xb5ca9000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0xb5bc8000)
        XXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.0 (0xb5bad000)
        XXXXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXXX.0 (0xb5b2d000)
        XXXXXXXXXX.3 => /lib/arm-linux-gnueabihf/XXXXXXXXXX.3 (0xb5ad0000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0xb59dd000)
        XXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXX.6 (0xb59c2000)
        XXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.1 (0xb599a000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0xb5987000)
        XXXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.6 (0xb5973000)
        XXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.0 (0xb5950000)
        XXXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXXX.1 (0xb593a000)
root@bpi-iot-ros-ai:/opt# apt-file search XXXXXXXXXXXXX
libicu-dev: /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX
libicu63: /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.63
libicu63: /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.63.1
root@bpi-iot-ros-ai:/opt# apt-get install libicu-dev
  icu-devtools
Suggested packages:
  icu-doc
  icu-devtools libicu-dev
0 upgraded, 2 newly installed, 0 to remove and 61 not upgraded.
        XXXXXXXXXXXXX.1 (0xbef8a000)
        XXXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXX.5 (0xb6c81000)
        XXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5 (0xb6898000)
        XXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXX.5 (0xb6598000)
        XXXXXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXXXXX.5 (0xb6470000)
        XXXXXXXXXXXXX.5 => /opt/Qt5.12.4_ARM_Linux/lib/XXXXXXXXXXXXX.5 (0xb6041000)
        XXXXXXXXXXXXX.0 => /lib/arm-linux-gnueabihf/XXXXXXXXXXXXX.0 (0xb600b000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0xb5f00000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0xb5e85000)
        libgcc_XXXX.1 => /lib/arm-linux-gnueabihf/libgcc_XXXX.1 (0xb5e5c000)
        XXXXXXX.6 => /lib/arm-linux-gnueabihf/XXXXXXX.6 (0xb5d62000)
        /lib/XXXXXXXXXXXXXXXXX.3 (0xb6f72000)
        XXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXX.1 (0xb5ce0000)
        XXXXXXXX.2 => /lib/arm-linux-gnueabihf/XXXXXXXX.2 (0xb5ccd000)
        XXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXX.0 (0xb5bec000)
        XXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.0 (0xb5bd1000)
        XXXXXXXXXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXXXXXXX.0 (0xb5b51000)
        XXXXXXXXXX.3 => /lib/arm-linux-gnueabihf/XXXXXXXXXX.3 (0xb5af4000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0xb5a01000)
        XXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXX.6 (0xb59e6000)
        XXXXXXXXX.1 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.1 (0xb59be000)
        XXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.6 (0xb59ab000)
        XXXXXXXXXXX.6 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXXXX.6 (0xb5997000)
        XXXXXXXXX.0 => /usr/lib/arm-linux-gnueabihf/XXXXXXXXX.0 (0xb5974000)
        XXXXXXXX.1 => /lib/arm-linux-gnueabihf/XXXXXXXX.1 (0xb595e000)
张静茹作者
4年5个月前 IP:江苏
867518
../configure -release -opensource \
-prefix /opt/Qt5.12.5_ARM_Linux \
-platform linux-aarch64-gnu-g++ \
-confirm-license \
-nomake examples \
-nomake tests \
-recheck-all
#-qt-xcb -opengl \
#-qt-zlib \
#-pkg-config \
#-qt-libpng \
#-qt-libjpeg \
#-qt-pcre \
#-qt-xcb \
#-qt-zlib \
#-pkg-config \
#-qt-libpng \
#-qt-libjpeg \
#-qt-pcre \
# -qt-xcb -opengl es2 \
#在3288上 只有 -opengl
#-confirm-license -recheck-all  \
#-opengl -qt-xcb \
#-nomake examples \
#-nomake tests \
#-v \
#-xplatform linux-arm-gnueabi-g++ \
#:-no-opengl -skip qtvirtualkeyboard
#:-opengl desktop -directfb \
#: -platform win32-g++
#-qt-xcb -v -qt-zlib
# apt-get build-dep qt5-default qtbase-opensource-src
# apt-get install libudev-dev libinput-dev libts-dev libxcb-xinerama0-dev libxcb-xinerama0 libx11-xcb-dev
# apt-get install "^libxcb.*"
# apt-get install libgl1-mesa-dev libglu1-mesa-dev
# apt install gperf bison flex
# apt install libnss3-dev
# apt install libssl1.0-dev qtdeclarative5-dev qtdeclarative5-private-dev
# libqt5x11extras5 libqt5x11extras5-dev
# apt-get install  libx11-dev libxv-dev
# apt-get install libglib2.0-dev
# apt-get install libgtk2.0-dev
# apt-get build-dep empathy
# apt-get install qt5-default qttools5-dev-tools
# apt install g++ gcc make perl
#could not find or load the Qt platform plugin "xcb"
#-qt-xcb
# Feature 'xcb' was enabled, but the pre-condition 'XXXXXXXXXXXread && features.xkbcommon && libs.xcb' failed.
#XXXXXXXXXXXXXXXXXXXXt/fujh0324/article/details/89160490
张静茹作者
4年4个月前 IP:江苏
868237
Linux Debian Conky
张静茹作者
3年11个月前 修改于 3年11个月前 IP:江苏
881315
删除文件
rm filename
rm -rf path
更改拥有者 权限等
chown username filename
/etc/passwd
root:x:0:0:root:/root:/bin/bash
注册名:口令:用户标识号:组标识号:用户名:用户主目录:命令解释程序
创建git
git init --bare XXXXXXXt
 //初始化git仓库
chown git XXXXXXXt
//更改所有者
gitosis-admin 中 XXXXXXXXXXnf文件 members添加 test
Gitosis管理git 权限
克隆地址
git@xxx.XXXXXXXXXXX:XXXXXXXt
ssh://git@xxx.XXXXXXXXXXX:22/opt/gittest/XXXXXXXt
张静茹作者
3年9个月前 IP:江苏
884932
Qt Creator 设置远程部署调试
输入远程地址 用户名 选择先使用密码登录创建密钥以后点部署公钥,输入密码,部署公钥成功 就不需要密码了
Kits中选择Device
启动调试失败 添加部署步骤 通过SFTP上传文件
依然失败 XXXXXXXXXXXXXXXX.5 等库缺失
张静茹作者
3年9个月前 修改于 3年9个月前 IP:江苏
884963
使用debian 10 的 source 更新debian 8的 source 后安装 libqt5.11
环境变量添加DISPLAY = localhost:10.0
qrc:/main.qml:3 module "XXXXXXXXXXntrols" is not installed
张静茹作者
3年8个月前 IP:江苏
884995
QCoreApplication::setAttribute(Qt::AA_EnableHighDpiScaling);
QGuiApplication app(argc, argv);
QQmlApplicationEngine engine;
const QUrl url(QStringLiteral("qrc:/main.qml"));
QObject::connect(&engine, &QQmlApplicationEngine::objectCreated,
&app, [url](QObject* obj, const QUrl& objUrl)
if (!obj && url == objUrl)
QCoreApplication::exit(-1);
}, Qt::QueuedConnection);
engine.load(url);
MainWindowVM MainWindowVM;
XXXXXXXXXXXXXXXtName("aaaaa");
XXXXXXXXXotContext()->setContextProperty(QT_STRINGIFY(MainWindowVM), &MainWindowVM);
return app.exec();
张静茹
进士 学者 机友 笔友
2010/12/30注册,5天11时前活动
