记录 泰克6B 系列示波器开源组件引用
张静茹2023/05/12软件综合 IP:山东
Open Source
  accountsservice
  query and manipulate user account information
<br>
  acl
  Access control list utilities
  acpid
  Advanced Configuration and Power Interface event daemon
  adduser
  add and remove users and groups
  adwaita-icon-theme
  default icon theme of GNOME (small subset)
  amd64-microcode
  Processor microcode firmware for AMD CPUs
  apparmor
  user-space parser utility for AppArmor
  apport
  automatically generate crash reports for debugging
  apport-symptoms
  symptom scripts for apport
  apt
  commandline package manager
  apt-transport-https
  https download transport for APT
  apt-utils
  package management related utility programs
  aspell-en
  English dictionary for GNU Aspell
  at
  Delayed job execution and batch processing
  at-spi2-core
  Assistive Technology Service Provider Interface (dbus core)
  attr
  Utilities for manipulating filesystem extended attributes
  authbind
  Allows non-root programs to bind() to low ports
  avahi-autoipd
  Avahi IPv4LL network address configuration daemon
  avahi-daemon
  Avahi mDNS/DNS-SD daemon
  base-files
  Debian base system miscellaneous files
  base-passwd
  Debian base system master password and group files
  bash
  GNU Bourne Again SHell
  bash-completion
  programmable completion for the bash shell
  bc
  GNU bc arbitrary precision calculator language
  bcache-tools
  bcache userspace tools
  bind9-host
  Version of 'host' bundled with BIND 9.X
  binutils
  GNU assembler, linker and binary utilities
  bsdmainutils
  collection of more utilities from FreeBSD
  bsdutils
  basic utilities from 4.4BSD-Lite
  btrfs-tools
  Checksumming Copy on Write Filesystem utilities
  build-essential
  Informational list of build-essential packages
  busybox-initramfs
  Standalone shell setup for initramfs
  busybox-static
  Standalone rescue shell with tons of builtin utilities
  byobu
  text window manager, shell multiplexer, integrated DevOps environment
  bzip2
  high-quality block-sorting file compressor - utilities
  ca-certificates
  Common CA certificates
  ca-certificates-java
  Common CA certificates (JKS keystore)
  cifs-utils
  Common Internet File System utilities
  cloud-guest-utils
  cloud guest utilities
  cloud-initramfs-copymods
  copy initramfs modules into root filesystem for later use
  cloud-initramfs-dyn-netconf
  write a network interface file in /run for BOOTIF
  colord
  system service to manage device colour profiles -- system daemon
  colord-data
  system service to manage device colour profiles -- data files
  command-not-found
  Suggest installation of packages in interactive bash sessions
  command-not-found-data
  Set of data files for command-not-found.
  console-setup
  console font and keymap setup program
  console-setup-linux
  Linux specific part of console-setup
  coreutils
  GNU core utilities
  cpio
  GNU cpio -- a program to manage archives of files
  cpp
  GNU C preprocessor (cpp)
  cpp-5
  GNU C preprocessor
  crda
  wireless Central Regulatory Domain Agent
  cron
  process scheduling daemon
  cryptsetup
  disk encryption support - startup scripts
  cryptsetup-bin
  disk encryption support - command line tools
  curl
  command line tool for transferring data with URL syntax
  dash
  POSIX-compliant shell
  dbus
  simple interprocess messaging system (daemon and utilities)
  dbus-x11
  simple interprocess messaging system (X11 deps)
  dconf-gsettings-backend
  simple configuration storage system - GSettings back-end
  dconf-service
  simple configuration storage system - D-Bus service
  debconf
  Debian configuration management system
  debconf-i18n
  full internationalization support for debconf
  debianutils
  Miscellaneous utilities specific to Debian
  default-jre-headless
  Standard Java or Java compatible Runtime (headless)
  dh-python
  Debian helper tools for packaging Python libraries and applications
  dictionaries-common
  spelling dictionaries - common utilities
  diffutils
  File comparison utilities
  distro-info-data
  information about the distributions' releases (data files)
  dkms
  Dynamic Kernel Module Support Framework
  dmeventd
  Linux Kernel Device Mapper event daemon
  dmidecode
  SMBIOS/DMI table decoder
  dmsetup
  Linux Kernel Device Mapper userspace library
  dns-root-data
  DNS root data including root zone and DNSSEC key
  dnsmasq-base
  Small caching DNS proxy and DHCP/TFTP server
  dnsutils
  Clients provided with BIND
  dosfstools
  utilities for making and checking MS-DOS FAT filesystems
  dpkg
  Debian package management system
  dpkg-dev
  Debian package development tools
  e2fslibs
  ext2/ext3/ext4 file system libraries
  e2fsprogs
  ext2/ext3/ext4 file system utilities
  ed
  classic UNIX line editor
  efibootmgr
  Interact with the EFI Boot Manager
  eject
  ejects CDs and operates CD-Changers under Linux
  emacsen-common
  Common facilities for all emacsen
  ethtool
  display or change Ethernet device settings
  exfat-fuse
  read and write exFAT driver for FUSE
  exfat-utils
  utilities to create, check, label and dump exFAT filesystem
  expect
  Automates interactive applications
  fakeroot
  tool for simulating superuser privileges
  fbi
  Linux frame buffer image viewer
  feh
  imlib2 based image viewer
  file
  Determines file type using "magic" numbers
  findutils
  utilities for finding files--find, xargs
  flex
  fast lexical analyzer generator
  fontconfig
  generic font configuration library - support binaries
  fontconfig-config
  generic font configuration library - configuration
  fonts-dejavu-core
  Vera font family derivate with additional characters
  fonts-ubuntu-font-family-conso
  Ubuntu Font Family Linux console fonts, sans-serif monospace
  friendly-recovery
  Make recovery more user-friendly
  ftp
  classical file transfer client
  fuse
  Filesystem in Userspace
  g++
  GNU C++ compiler
  g++-5
  GNU C++ compiler
  gawk
  GNU awk, a pattern scanning and processing language
  gcc
  GNU C compiler
  gcc-5
  GNU C compiler
  gcc-5-base
  GCC, the GNU Compiler Collection (base package)
  gcc-6-base
  gcc-7-base
  gcc-8-base
  gcc-9-base
  gcr
  GNOME crypto services (daemon and tools)
  gdb
  GNU Debugger
  gdbserver
  GNU Debugger (remote server)
  gdisk
  GPT fdisk text-mode partitioning tool
  geoip-database
  IP lookup command line tools that use the GeoIP library (country database)
  gettext
  GNU Internationalization utilities
  gettext-base
  GNU Internationalization utilities for the base system
  ghostscript
  interpreter for the PostScript language and for PDF
  gir1.2-glib-2.0
  Introspection data for GLib, GObject, Gio and GModule
  git
  fast, scalable, distributed revision control system
  git-man
  fast, scalable, distributed revision control system (manual pages)
  glib-networking
  network-related giomodules for GLib
  glib-networking-common
  network-related giomodules for GLib - data files
  glib-networking-services
  network-related giomodules for GLib - D-Bus services
  gnome-keyring
  GNOME keyring services (daemon and tools)
  gnupg
  GNU privacy guard - a free PGP replacement
  gpgv
  GNU privacy guard - signature verification tool
  grep
  GNU grep, egrep and fgrep
  groff-base
  GNU troff text-formatting system (base system components)
  grub-common
  GRand Unified Bootloader (common files)
  grub-efi-amd64
  GRand Unified Bootloader, version 2 (EFI-AMD64 version)
  grub-efi-amd64-bin
  GRand Unified Bootloader, version 2 (EFI-AMD64 binaries)
  grub-efi-amd64-signed
  GRand Unified Bootloader, version 2 (EFI-AMD64 version, signed)
  grub-legacy-ec2
  Handles update-grub for ec2 instances
  grub2-common
  GRand Unified Bootloader (common files for version 2)
  gsettings-desktop-schemas
  GSettings desktop-wide schemas
  gsfonts
  Fonts for the Ghostscript interpreter(s)
  gstreamer1.0-plugins-base
  GStreamer plugins from the "base" set
  gstreamer1.0-plugins-good
  GStreamer plugins from the "good" set
  gstreamer1.0-x
  GStreamer plugins for X11 and Pango
  guacamole
  HTML5 web application for accessing remote desktops
  guacd
  Guacamole proxy daemon
  gzip
  GNU compression utilities
  hdparm
  tune hard disk parameters for high performance
  hicolor-icon-theme
  default fallback theme for XXXXXXXXXXXXXXX icon themes
  hostname
  utility to set/show the host name or domain name
  humanity-icon-theme
  Humanity Icon theme
  icu-devtools
  Development utilities for International Components for Unicode
  ifenslave
  configure network interfaces for parallel routing (bonding)
  ifupdown
  high level tools to configure network interfaces
  indicator-application
  Application Indicators
  info
  Standalone GNU Info documentation browser
  init
  System-V-like init utilities - metapackage
  init-system-helpers
  helper tools for all init systems
  initramfs-tools
  generic modular initramfs generator (automation)
  initramfs-tools-bin
  binaries used by initramfs-tools
  initramfs-tools-core
  generic modular initramfs generator (core tools)
  initscripts
  scripts for initializing and shutting down the system
  insserv
  boot sequence organizer using LSB init.d script dependency information
  install-info
  Manage installed documentation in info format
  installation-report
  system installation report
  intel-microcode
  Processor microcode firmware for Intel CPUs
  iproute2
  networking and traffic control tools
  iptables
  administration tools for packet filtering and NAT
  iputils-arping
  Tool to send ICMP echo requests to an ARP address
  iputils-ping
  Tools to test the reachability of network hosts
  iputils-tracepath
  Tools to trace the network path to a remote host
  irqbalance
  Daemon to balance interrupts for SMP systems
  isc-dhcp-client
  DHCP client for automatically obtaining an IP address
  isc-dhcp-common
  common files used by all of the isc-dhcp packages
  iso-codes
  ISO language, territory, currency, script codes and their translations
  iucode-tool
  Intel processor microcode tool
  iw
  tool for configuring Linux wireless devices
  java-common
  Base package for Java runtimes
  jemalloc
  Tek jemalloc 5.2
  kbd
  Linux console font and keytable utilities
  keyboard-configuration
  system-wide keyboard preferences
  keyutils
  Linux Key Management Utilities
  klibc-utils
  small utilities built with klibc for early boot
  kmod
  tools for managing Linux kernel modules
  krb5-locales
  Internationalization support for MIT Kerberos
  language-pack-en
  translation updates for language English
  language-pack-en-base
  translations for language English
  language-selector-common
  Language selector for Ubuntu
  laptop-detect
  attempt to detect a laptop
  less
  pager program similar to more
  libaa1
  ASCII art library
  libaccountsservice0
  query and manipulate user account information - shared libraries
  libacl1
  Access control list shared library
  libaio1
  Linux kernel AIO access library - shared library
  libalgorithm-diff-perl
  module to find differences between files
  libalgorithm-diff-xs-perl
  module to find differences between files (XS accelerated)
  libalgorithm-merge-perl
  Perl module for three-way merge of textual data
  libapparmor-perl
  AppArmor library Perl bindings
  libapparmor1
  changehat AppArmor library
  libappindicator3-1
  libapt-inst2.0
  deb package format runtime library
  libapt-pkg5.0
  package management runtime library
  libasan2
  AddressSanitizer -- a fast memory error detector
  libasan4
  libasn1-8-heimdal
  Heimdal Kerberos - ASN.1 library
  libasound2
  shared library for ALSA applications
  libasound2-data
  Configuration files and profiles for ALSA drivers
  libaspell15
  GNU Aspell spell-checker runtime library
  libasprintf-dev
  GNU Internationalization library development files
  libasprintf0v5
  GNU library to use fprintf and friends in C++
  libassuan0
  IPC library for the GnuPG components
  libasyncns0
  Asynchronous name service query library
  libatk-bridge2.0-0
  AT-SPI 2 toolkit bridge - shared library
  libatk1.0-0
  ATK accessibility toolkit
  libatk1.0-data
  Common files for the ATK accessibility toolkit
  libatm1
  shared library for ATM (Asynchronous Transfer Mode)
  libatomic1
  support library providing __atomic built-in functions
  libatspi2.0-0
  Assistive Technology Service Provider Interface - shared library
  libattr1
  Extended attribute shared library
  libaudit-common
  Dynamic library for security auditing - common files
  libaudit1
  libavahi-client3
  Avahi client library
  libavahi-common-data
  Avahi common data files
  libavahi-common3
  Avahi common library
  libavahi-core7
  Avahi's embeddable mDNS/DNS-SD library
  libavc1394-0
  control IEEE 1394 audio/video devices
  libbabeltrace-ctf1
  Common Trace Format (CTF) library
  libbabeltrace1
  Babeltrace conversion libraries
  libbind9-140
  BIND9 Shared Library used by BIND
  libblkid1
  block device ID library
  libbluetooth3
  Library to use the BlueZ Linux Bluetooth stack
  libboost-filesystem1.58.0
  filesystem operations (portable paths, iteration over directories, etc) in C++
  libboost-system1.58.0
  Operating system (e.g. diagnostics support) library
  libbsd0
  utility functions from BSD systems - shared library
  libbz2-1.0
  high-quality block-sorting file compressor library - runtime
  libc-bin
  GNU C Library: Binaries
  libc-dev-bin
  GNU C Library: Development binaries
  libc6
  GNU C Library: Shared libraries
  libc6-dbg
  GNU C Library: detached debugging symbols
  libc6-dev
  GNU C Library: Development Libraries and Header Files
  libcaca0
  colour ASCII art library
  libcairo-gobject2
  Cairo 2D vector graphics library (GObject library)
  libcairo-script-interpreter2
  Cairo 2D vector graphics library (script interpreter)
  libcairo2
  libcap-ng0
  An alternate POSIX capabilities library
  libcap2
  POSIX 1003.1e capabilities (library)
  libcap2-bin
  POSIX 1003.1e capabilities (utilities)
  libcapnp-0.5.3
  Cap'n Proto C++ library
  libcc1-0
  GCC cc1 plugin for GDB
  libcdparanoia0
  audio extraction tool for sampling CDs (library)
  libcilkrts5
  Intel Cilk Plus language extensions (runtime)
  libcolord2
  system service to manage device colour profiles -- runtime
  libcolorhug2
  library to access the ColorHug colourimeter -- runtime
  libcomerr2
  common error description library
  libcommons-collections3-java
  Apache Commons Collections - Extended Collections API for Java
  libcommons-dbcp-java
  Database Connection Pooling Services
  libcommons-pool-java
  pooling implementation for Java objects
  libcroco3
  Cascading Style Sheet (CSS) parsing and manipulation toolkit
  libcrypto++-dev
  General purpose cryptographic library - C++ development
  libcrypto++9v5
  General purpose cryptographic library - shared library
  libcryptsetup4
  disk encryption support - shared library
  libcups2
  Common UNIX Printing System(tm) - Core library
  libcupsfilters1
  OpenPrinting CUPS Filters - Shared library
  libcupsimage2
  Common UNIX Printing System(tm) - Raster image library
  libcurl3
  easy-to-use client-side URL transfer library (OpenSSL flavour)
  libcurl3-gnutls
  easy-to-use client-side URL transfer library (GnuTLS flavour)
  libdaemon0
  lightweight C library for daemons - runtime library
  libdatrie1
  Double-array trie library
  libdb5.3
  Berkeley v5.3 Database Libraries [runtime]
  libdbus-1-3
  simple interprocess messaging system (library)
  libdbus-glib-1-2
  simple interprocess messaging system (GLib-based shared library)
  libdbusmenu-glib4
  library for passing menus over DBus
  libdbusmenu-gtk3-4
  library for passing menus over DBus - GTK+ version
  libdconf1
  simple configuration storage system - runtime library
  libdebconfclient0
  Debian Configuration Management System (C-implementation library)
  libdevmapper-event1.02.1
  Linux Kernel Device Mapper event support library
  libdevmapper1.02.1
  libdns-export162
  Exported DNS Shared Library
  libdns162
  DNS Shared Library used by BIND
  libdouble-conversion1v5
  routines to convert IEEE floats to and from strings
  libdpkg-perl
  Dpkg perl modules
  libdrm-amdgpu1
  Userspace interface to amdgpu-specific kernel DRM services -- runtime
  libdrm-common
  Userspace interface to kernel DRM services -- common files
  libdrm-dev
  Userspace interface to kernel DRM services -- development files
  libdrm-intel1
  Userspace interface to intel-specific kernel DRM services -- runtime
  libdrm-nouveau2
  Userspace interface to nouveau-specific kernel DRM services -- runtime
  libdrm-radeon1
  Userspace interface to radeon-specific kernel DRM services -- runtime
  libdrm2
  Userspace interface to kernel DRM services -- runtime
  libdumbnet1
  dumb, portable networking library -- shared library
  libdv4
  software library for DV format digital video (runtime lib)
  libecj-java
  Eclipse Java compiler (library)
  libedit2
  BSD editline and history libraries
  libefivar0
  Library to manage UEFI variables
  libegl1-mesa
  free implementation of the EGL API -- runtime
  libelf1
  library to read and write ELF files
  libepoxy0
  OpenGL function pointer management library
  liberror-perl
  Perl module for error/exception handling in an OO-ish way
  libestr0
  Helper functions for handling strings (lib)
  libevdev2
  wrapper library for evdev devices
  libevent-2.0-5
  Asynchronous event notification library
  libexif12
  library to parse EXIF files
  libexpat1
  XML parsing C library - runtime library
  libexpat1-dev
  XML parsing C library - development kit
  libfakeroot
  tool for simulating superuser privileges - shared libraries
  libfdisk1
  fdisk partitioning library
  libffi6
  Foreign Function Interface library runtime
  libfftw3-bin
  Library for computing Fast Fourier Transforms - Tools
  libfftw3-dev
  Library for computing Fast Fourier Transforms - development
  libfftw3-double3
  Library for computing Fast Fourier Transforms - Double precision
  libfftw3-long3
  Library for computing Fast Fourier Transforms - Long precision
  libfftw3-quad3
  Library for computing Fast Fourier Transforms - Quad precision
  libfftw3-single3
  Library for computing Fast Fourier Transforms - Single precision
  libfile-copy-recursive-perl
  Perl extension for recursively copying files and directories
  libfile-fcntllock-perl
  Perl module for file locking with fcntl(2)
  libfl-dev
  static library for flex (a fast lexical analyzer generator)
  libflac8
  Free Lossless Audio Codec - runtime C library
  libfontconfig1
  generic font configuration library - runtime
  libfontenc1
  X11 font encoding library
  libfreetype6
  FreeType 2 font engine, shared library files
  libfribidi0
  Free Implementation of the Unicode BiDi algorithm
  libfuse2
  Filesystem in Userspace (library)
  libgbm1
  generic buffer management API -- runtime
  libgcc-5-dev
  GCC support library (development files)
  libgcc-7-dev
  libgcc1
  GCC support library
  libgck-1-0
  Glib wrapper library for PKCS#11 - runtime
  libgcr-3-common
  Library for Crypto UI related tasks - common files
  libgcr-base-3-1
  Library for Crypto related tasks
  libgcr-ui-3-1
  libgcrypt20
  LGPL Crypto library - runtime library
  libgd3
  GD Graphics Library
  libgdbm3
  GNU dbm database routines (runtime version)
  libgdk-pixbuf2.0-0
  GDK Pixbuf library
  libgdk-pixbuf2.0-common
  GDK Pixbuf library - data files
  libgeoip1
  non-DNS IP-to-country resolver library
  libgettextpo-dev
  libgettextpo0
  libgif7
  library for GIF images (library)
  libgirepository-1.0-1
  Library for handling GObject introspection data (runtime library)
  libgl1-mesa-dri
  free implementation of the OpenGL API -- DRI modules
  libgl1-mesa-glx
  free implementation of the OpenGL API -- GLX runtime
  libglapi-mesa
  free implementation of the GL API -- shared library
  libglib2.0-0
  GLib library of C routines
  libglib2.0-bin
  Programs for the GLib library
  libglib2.0-data
  Common files for GLib library
  libglib2.0-dev
  Development files for the GLib library
  libgmp-dev
  Multiprecision arithmetic library developers tools
  libgmp10
  libgmpxx4ldbl
  Multiprecision arithmetic library (C++ bindings)
  libgnutls-dev
  GNU TLS library - development files
  libgnutls-openssl27
  GNU TLS library - OpenSSL wrapper
  libgnutls28-dev
  dummy transitional package for GNU TLS library - development files
  libgnutls30
  GNU TLS library - main runtime library
  libgnutlsxx28
  GNU TLS library - C++ runtime library
  libgomp1
  GCC OpenMP (GOMP) support library
  libgpg-error0
  library for common error values and messages in GnuPG components
  libgphoto2-6
  gphoto2 digital camera library
  libgphoto2-l10n
  gphoto2 digital camera library - localized messages
  libgphoto2-port12
  gphoto2 digital camera port library
  libgpm2
  General Purpose Mouse - shared library
  libgraphite2-3
  Font rendering engine for Complex Scripts -- library
  libgs9
  interpreter for the PostScript language and for PDF - Library
  libgs9-common
  interpreter for the PostScript language and for PDF - common files
  libgssapi-krb5-2
  MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
  libgssapi3-heimdal
  Heimdal Kerberos - GSSAPI support library
  libgstreamer-plugins-base1.0-0
  GStreamer libraries from the "base" set
  libgstreamer-plugins-good1.0-0
  GStreamer development files for libraries from the "good" set
  libgstreamer1.0-0
  Core GStreamer libraries and elements
  libgtk-3-0
  GTK+ graphical user interface library
  libgtk-3-bin
  programs for the GTK+ graphical user interface library
  libgtk-3-common
  common files for the GTK+ graphical user interface library
  libgtk2.0-0
  libgtk2.0-bin
  libgtk2.0-common
  libguac-client-vnc0
  VNC support plugin for Guacamole
  libguac5
  Core Guacamole library used by guacd and client plugins
  libgudev-1.0-0
  GObject-based wrapper library for libudev
  libgusb2
  GLib wrapper around libusb1
  libharfbuzz-icu0
  OpenType text shaping engine ICU backend
  libharfbuzz0b
  OpenType text shaping engine (shared library)
  libhcrypto4-heimdal
  Heimdal Kerberos - crypto library
  libheimbase1-heimdal
  Heimdal Kerberos - Base library
  libheimntlm0-heimdal
  Heimdal Kerberos - NTLM support library
  libhogweed4
  low level cryptographic library (public-key cryptos)
  libhunspell-1.3-0
  spell checker and morphological analyzer (shared library)
  libhx509-5-heimdal
  Heimdal Kerberos - X509 support library
  libhyphen0
  ALTLinux hyphenation library - shared library
  libice-dev
  X11 Inter-Client Exchange library (development headers)
  libice6
  libicu55
  libid3tag0
  ID3 tag reading library from the MAD project
  libidn11
  GNU Libidn library, implementation of IETF IDN specifications
  libidn11-dev
  Development files for GNU Libidn, an IDN library
  libiec61883-0
  an partial implementation of IEC 61883
  libieee1284-3
  cross-platform library for parallel port access
  libijs-0.35
  IJS raster image transport protocol: shared library
  libimlib2
  image loading, rendering, saving library
  libindicator3-7
  panel indicator applet - shared library
  libinput-bin
  input device management and event handling library - udev quirks
  libinput10
  input device management and event handling library - shared library
  libisc-export160
  Exported ISC Shared Library
  libisc160
  ISC Shared Library used by BIND
  libisccc140
  Command Channel Library used by BIND
  libisccfg140
  Config File Handling Library used by BIND
  libisl15
  manipulating sets and relations of integer points bounded by linear constraints
  libitm1
  GNU Transactional Memory Library
  libjack-jackd2-0
  JACK Audio Connection Kit (libraries)
  libjavascriptcoregtk-4.0-18
  JavaScript engine library from WebKitGTK+
  libjbig0
  JBIGkit libraries
  libjbig2dec0
  JBIG2 decoder library - shared libraries
  libjpeg-dev
  Independent JPEG Group's JPEG runtime library (dependency package)
  libjpeg-progs
  Programs for manipulating JPEG files
  libjpeg-turbo8
  IJG JPEG compliant runtime library.
  libjpeg-turbo8-dev
  Development files for the IJG JPEG library
  libjpeg8
  libjpeg8-dev
  libjpeg9
  libjson-c2
  JSON manipulation library - shared library
  libjson-glib-1.0-0
  GLib JSON manipulation library
  libjson-glib-1.0-common
  GLib JSON manipulation library (common files)
  libk5crypto3
  MIT Kerberos runtime libraries - Crypto Library
  libkeyutils1
  Linux Key Management Utilities (library)
  libklibc
  minimal libc subset for use with initramfs
  libkmod2
  libkmod shared library
  libkrb5-26-heimdal
  Heimdal Kerberos - libraries
  libkrb5-3
  libkrb5support0
  MIT Kerberos runtime libraries - Support library
  liblcms2-2
  Little CMS 2 color management library
  libldap-2.4-2
  OpenLDAP libraries
  libldb1
  LDAP-like embedded database - shared library
  libllvm6.0
  Modular compiler and toolchain technologies, runtime library
  liblocale-gettext-perl
  module using libc functions for internationalization in Perl
  liblsan0
  LeakSanitizer -- a memory leak detector (runtime)
  libltdl7
  System independent dlopen wrapper for GNU libtool
  liblvm2app2.2
  LVM2 application library
  liblvm2cmd2.02
  LVM2 command library
  liblwres141
  Lightweight Resolver Library used by BIND
  liblxc1
  Linux Containers userspace tools (library)
  liblz4-1
  Fast LZ compression algorithm library - runtime
  liblzma5
  XZ-format compression library
  liblzo2-2
  data compression library
  libmagic1
  File type determination library using "magic" numbers
  libmbim-glib4
  Support library to use the MBIM protocol
  libmbim-proxy
  Proxy to communicate with MBIM ports
  libmirclient9
  Display server for Ubuntu - client library
  libmircommon7
  Display server for Ubuntu - shared library
  libmircore1
  libmirprotobuf3
  Display server for Ubuntu - RPC definitions
  libmm-glib0
  D-Bus service for managing modems - shared libraries
  libmnl0
  minimalistic Netlink communication library
  libmount1
  device mounting library
  libmpc3
  multiple precision complex floating-point library
  libmpdec2
  library for decimal floating point arithmetic (runtime library)
  libmpfr4
  multiple precision floating-point computation
  libmpx0
  Intel memory protection extensions (runtime)
  libmpx2
  libmspack0
  library for Microsoft compression formats (shared library)
  libmtdev1
  Multitouch Protocol Translation Library - shared library
  libncurses5
  shared libraries for terminal handling
  libncursesw5
  shared libraries for terminal handling (wide character support)
  libndp0
  Library for Neighbor Discovery Protocol
  libnetfilter-conntrack3
  Netfilter netlink-conntrack library
  libnettle6
  low level cryptographic library (symmetric and one-way cryptos)
  libnewt0.52
  Not Erik's Windowing Toolkit - text mode windowing with slang
  libnfnetlink0
  Netfilter netlink library
  libnfsidmap2
  NFS idmapping library
  libnih1
  NIH Utility Library
  libnl-3-200
  library for dealing with netlink sockets
  libnl-genl-3-200
  library for dealing with netlink sockets - generic netlink
  libnm0
  GObject-based client library for NetworkManager
  libnma-common
  library for wireless and mobile dialogs - common files
  libnma0
  library for wireless and mobile dialogs (libnm version)
  libnotify4
  sends desktop notifications to a notification daemon
  libnspr4
  NetScape Portable Runtime Library
  libnss-mdns
  NSS module for Multicast DNS name resolution
  libnss3
  Network Security Service libraries
  libnss3-nssdb
  Network Security Security libraries - shared databases
  libnuma1
  Libraries for controlling NUMA policy
  libogg0
  Ogg bitstream library
  libopts25
  automated option processing library based on autogen
  libopus0
  Opus codec runtime library
  liborc-0.4-0
  Library of Optimized Inner Loops Runtime Compiler
  libossp-uuid-dev
  OSSP uuid ISO-C and C++ - headers and static libraries
  libossp-uuid16
  OSSP uuid ISO-C and C++ - shared library
  libp11-kit-dev
  library for loading and coordinating access to PKCS#11 modules - development
  libp11-kit-gnome-keyring
  GNOME keyring module for the PKCS#11 module loading library
  libp11-kit0
  library for loading and coordinating access to PKCS#11 modules - runtime
  libpam-gnome-keyring
  PAM module to unlock the GNOME keyring upon login
  libpam-modules
  Pluggable Authentication Modules for PAM
  libpam-modules-bin
  Pluggable Authentication Modules for PAM - helper binaries
  libpam-runtime
  Runtime support for the PAM library
  libpam-systemd
  system and service manager - PAM module
  libpam0g
  Pluggable Authentication Modules library
  libpango-1.0-0
  Layout and rendering of internationalized text
  libpangocairo-1.0-0
  libpangoft2-1.0-0
  libpaper1
  library for handling paper characteristics
  libparted2
  disk partition manipulator - shared library
  libpcap0.8
  system interface for user-level packet capture
  libpci3
  Linux PCI Utilities (shared library)
  libpciaccess0
  Generic PCI access library for X
  libpcre16-3
  Perl 5 Compatible Regular Expression Library - 16 bit runtime files
  libpcre3
  Perl 5 Compatible Regular Expression Library - runtime files
  libpcre3-dev
  Perl 5 Compatible Regular Expression Library - development files
  libpcre32-3
  Perl 5 Compatible Regular Expression Library - 32 bit runtime files
  libpcrecpp0v5
  Perl 5 Compatible Regular Expression Library - C++ runtime files
  libpcsclite1
  Middleware to access a smart card using PC/SC (library)
  libperl5.22
  shared Perl library
  libpipeline1
  pipeline manipulation library
  libpixman-1-0
  pixel-manipulation library for X and cairo
  libpixman-1-dev
  pixel-manipulation library for X and cairo (development files)
  libplymouth4
  graphical boot animation and logger - shared libraries
  libpng12-0
  PNG library - runtime
  libpolkit-agent-1-0
  PolicyKit Authentication Agent API
  libpolkit-backend-1-0
  PolicyKit backend API
  libpolkit-gobject-1-0
  PolicyKit Authorization API
  libpopt0
  lib for parsing cmdline parameters
  libprocps4
  library for accessing process information from /proc
  libprotobuf-lite9v5
  protocol buffers C++ library (lite version)
  libproxy1v5
  automatic proxy configuration management library (shared)
  libpthread-stubs0-dev
  pthread stubs not provided by native libc, development files
  libpulse0
  PulseAudio client libraries
  libpython-stdlib
  interactive high-level object-oriented language (default python version)
  libpython2.7
  Shared Python runtime library (version 2.7)
  libpython2.7-dev
  Header files and a static library for Python (v2.7)
  libpython2.7-minimal
  Minimal subset of the Python language (version 2.7)
  libpython2.7-stdlib
  Interactive high-level object-oriented language (standard library, version 2.7)
  libpython3-stdlib
  interactive high-level object-oriented language (default python3 version)
  libpython3.5
  Shared Python runtime library (version 3.5)
  libpython3.5-minimal
  Minimal subset of the Python language (version 3.5)
  libpython3.5-stdlib
  Interactive high-level object-oriented language (standard library, version 3.5)
  libqmi-glib5
  Support library to use the Qualcomm MSM Interface (QMI) protocol
  libqmi-proxy
  Proxy to communicate with QMI ports
  libqt5core5a
  Qt 5 core module
  libqt5dbus5
  Qt 5 D-Bus module
  libqt5gui5
  Qt 5 GUI module
  libqt5network5
  Qt 5 network module
  libqt5opengl5
  Qt 5 OpenGL module
  libqt5printsupport5
  Qt 5 print support module
  libqt5qml5
  Qt 5 QML module
  libqt5quick5
  Qt 5 Quick library
  libqt5sql5
  Qt 5 SQL module
  libqt5sql5-sqlite
  Qt 5 SQLite 3 database driver
  libqt5svg5
  Qt 5 SVG module
  libqt5webkit5
  Web content engine library for Qt
  libqt5widgets5
  Qt 5 widgets module
  libquadmath0
  GCC Quad-Precision Math Library
  libquazip-headers
  C++ wrapper for ZIP/UNZIP (development header files)
  libquazip5-1
  C++ wrapper wrapper for ZIP/UNZIP (Qt5 build)
  libquazip5-dev
  C++ wrapper wrapper for ZIP/UNZIP (development files, Qt5 build)
  libraw1394-11
  library for direct access to IEEE 1394 bus (aka FireWire)
  libreadline5
  GNU readline and history libraries, run-time libraries
  libreadline6
  librest-0.7-0
  REST service access library
  libroken18-heimdal
  Heimdal Kerberos - roken support library
  librsvg2-2
  SAX-based renderer library for SVG files (runtime)
  librsvg2-common
  SAX-based renderer library for SVG files (extra runtime)
  librtmp1
  toolkit for RTMP streams (shared library)
  libsamplerate0
  Audio sample rate conversion library
  libsane
  API library for scanners
  libsane-common
  API library for scanners -- documentation and support files
  libsasl2-2
  Cyrus SASL - authentication abstraction library
  libsasl2-modules
  Cyrus SASL - pluggable authentication modules
  libsasl2-modules-db
  Cyrus SASL - pluggable authentication modules (DB)
  libseccomp2
  high level interface to Linux seccomp filter
  libsecret-1-0
  Secret store
  libsecret-common
  Secret store (common files)
  libselinux1
  SELinux runtime shared libraries
  libsemanage-common
  Common files for SELinux policy management libraries
  libsemanage1
  SELinux policy management library
  libsensors4
  library to read temperature/voltage/fan sensors
  libsepol1
  SELinux library for manipulating binary security policies
  libservlet3.0-java
  Servlet 3.0 and JSP 2.2 Java API classes
  libshout3
  MP3/Ogg Vorbis broadcast streaming library
  libsigsegv2
  Library for handling page faults in a portable way
  libslang2
  S-Lang programming library - runtime version
  libsm-dev
  X11 Session Management library (development headers)
  libsm6
  libsmartcols1
  smart column output alignment library
  libsndfile1
  Library for reading/writing audio files
  libsoup-gnome2.4-1
  HTTP library implementation in C -- GNOME support library
  libsoup2.4-1
  HTTP library implementation in C -- Shared library
  libspeex1
  The Speex codec runtime library
  libsqlite3-0
  SQLite 3 shared library
  libss2
  command-line interface parsing library
  libssl1.0.0
  Secure Sockets Layer toolkit - shared libraries
  libstartup-notification0
  library for program launch feedback (shared library)
  libstdc++-5-dev
  GNU Standard C++ Library v3 (development files)
  libstdc++-7-dev
  libstdc++6
  libsystemd0
  systemd utility library
  libtag1v5
  audio meta-data library
  libtag1v5-vanilla
  audio meta-data library - vanilla flavour
  libtalloc2
  hierarchical pool based memory allocator
  libtasn1-6
  Manage ASN.1 structures (runtime)
  libtasn1-6-dev
  Manage ASN.1 structures (development)
  libtasn1-doc
  Manage ASN.1 structures (documentation)
  libtcl8.6
  Tcl (the Tool Command Language) v8.6 - run-time library files
  libtdb1
  Trivial Database - shared library
  libtevent0
  talloc-based event loop library - shared library
  libtext-charwidth-perl
  get display widths of characters on the terminal
  libtext-iconv-perl
  converts between character sets in Perl
  libtext-wrapi18n-perl
  internationalized substitute of Text::Wrap
  libthai-data
  Data files for Thai language support library
  libthai0
  libtheora0
  Theora Video Compression Codec
  libtiff5
  Tag Image File Format (TIFF) library
  libtinfo5
  shared low-level terminfo library for terminal handling
  libtirpc1
  transport-independent RPC library
  libtk8.6
  Tk toolkit for Tcl and X11 v8.6 - run-time files
  libtomcat7-java
  Servlet and JSP engine -- core libraries
  libtsan0
  ThreadSanitizer -- a Valgrind-based detector of data races (runtime)
  libtxc-dxtn-s2tc0
  Texture compression library for Mesa
  libubsan0
  UBSan -- undefined behaviour sanitizer (runtime)
  libudev1
  libudev shared library
  libunistring0
  Unicode string library for C
  libusb-0.1-4
  userspace USB programming library
  libusb-1.0-0
  libusb-1.0-0-dev
  userspace USB programming library development files
  libusb-1.0-doc
  documentation for userspace USB programming
  libustr-1.0-1
  Micro string library: shared library
  libutempter0
  privileged helper for utmp/wtmp updates (runtime)
  libuuid1
  Universally Unique ID library
  libv4l-0
  Collection of video4linux support libraries
  libv4lconvert0
  Video4linux frame format conversion library
  libvisual-0.4-0
  audio visualization framework
  libvncclient1
  API to write one's own VNC server - client library
  libvncserver-config
  API to write one's own VNC server - library utility
  libvncserver-dev
  API to write one's own VNC server - development files
  libvncserver1
  libvorbis0a
  decoder library for Vorbis General Audio Compression Codec
  libvorbisenc2
  encoder library for Vorbis General Audio Compression Codec
  libvpx3
  VP8 and VP9 video codec (shared library)
  libwacom-bin
  Wacom model feature query library -- binaries
  libwacom-common
  Wacom model feature query library (common files)
  libwacom2
  libwavpack1
  audio codec (lossy and lossless) - library
  libwayland-client0
  wayland compositor infrastructure - client library
  libwayland-cursor0
  wayland compositor infrastructure - cursor library
  libwayland-egl1-mesa
  implementation of the Wayland EGL platform -- runtime
  libwayland-server0
  wayland compositor infrastructure - server library
  libwbclient0
  Samba winbind client library
  libwebp5
  Lossy compression of digital photographic images.
  libwebpdemux1
  libwind0-heimdal
  Heimdal Kerberos - stringprep implementation
  libwnck-common
  Window Navigator Construction Kit - common files
  libwnck22
  Window Navigator Construction Kit - runtime files
  libwrap0
  Wietse Venema's TCP wrappers library
  libx11-6
  X11 client-side library
  libx11-data
  libx11-dev
  X11 client-side library (development headers)
  libx11-doc
  X11 client-side library (development documentation)
  libx11-xcb1
  Xlib/XCB interface library
  libxatracker2
  X acceleration library -- runtime
  libxau-dev
  X11 authorisation library (development headers)
  libxau6
  libxaw7
  X11 Athena Widget library
  libxcb-dri2-0
  X C Binding, dri2 extension
  libxcb-dri3-0
  X C Binding, dri3 extension
  libxcb-glx0
  X C Binding, glx extension
  libxcb-icccm4
  utility libraries for X C Binding -- icccm
  libxcb-image0
  utility libraries for X C Binding -- image
  libxcb-keysyms1
  utility libraries for X C Binding -- keysyms
  libxcb-present0
  X C Binding, present extension
  libxcb-randr0
  X C Binding, randr extension
  libxcb-render-util0
  utility libraries for X C Binding -- render-util
  libxcb-render0
  X C Binding, render extension
  libxcb-render0-dev
  X C Binding, render extension, development files
  libxcb-shape0
  X C Binding, shape extension
  libxcb-shm0
  X C Binding, shm extension
  libxcb-shm0-dev
  X C Binding, shm extension, development files
  libxcb-sync1
  X C Binding, sync extension
  libxcb-util1
  utility libraries for X C Binding -- atom, aux and event
  libxcb-xfixes0
  X C Binding, xfixes extension
  libxcb-xinerama0
  X C Binding, xinerama extension
  libxcb-xkb1
  X C Binding, XKEYBOARD extension
  libxcb1
  X C Binding
  libxcb1-dev
  X C Binding, development files
  libxcomposite1
  X11 Composite extension library
  libxcursor1
  X cursor management library
  libxdamage1
  X11 damaged region extension library
  libxdmcp-dev
  libxdmcp6
  X11 Display Manager Control Protocol library
  libxext-dev
  X11 miscellaneous extensions library (development headers)
  libxext6
  X11 miscellaneous extension library
  libxfce4ui-1-0
  widget library for Xfce - Gtk+2 variant
  libxfce4ui-common
  common files for libxfce4ui
  libxfce4util-bin
  tools for libxfce4util
  libxfce4util-common
  common files for libxfce4util
  libxfce4util7
  Utility functions library for Xfce4
  libxfconf-0-2
  Client library for Xfce4 configure interface
  libxfixes-dev
  X11 miscellaneous 'fixes' extension library (development headers)
  libxfixes3
  libxfont1
  X11 font rasterisation library
  libxfont2
  libxft2
  FreeType-based font drawing library for X
  libxi-dev
  X11 Input extension library (development headers)
  libxi6
  libxinerama1
  X11 Xinerama extension library
  libxkbcommon-x11-0
  library to create keymaps with the XKB X11 protocol
  libxkbcommon0
  library interface to the XKB compiler - shared library
  libxkbfile1
  X11 keyboard file manipulation library
  libxml2
  GNOME XML library
  libxmlsec1
  XML security library
  libxmlsec1-openssl
  Openssl engine for the XML security library
  libxmu6
  X11 miscellaneous utility library
  libxmuu1
  X11 miscellaneous micro-utility library
  libxpm4
  X11 pixmap library
  libxrandr-dev
  X11 RandR extension library (development headers)
  libxrandr2
  libxrender-dev
  X Rendering Extension client library (development files)
  libxrender1
  libxres1
  X11 Resource extension library
  libxshmfence1
  X shared memory fences - shared library
  libxslt1.1
  XSLT 1.0 processing library - runtime library
  libxss1
  X11 Screen Saver extension library
  libxt6
  X11 toolkit intrinsics library
  libxtables11
  netfilter xtables library
  libxtst6
  X11 Testing -- Record extension library
  libxv1
  X11 Video extension library
  libxvmc1
  libxxf86dga1
  X11 Direct Graphics Access extension library
  libxxf86vm1
  X11 XFree86 video mode extension library
  libzstd1
  fast lossless compression algorithm
  linux-base
  Linux image base package
  linux-firmware
  Firmware for Linux kernel drivers
  linux-headers-4.15.0-58
  Header files related to Linux kernel version 4.15.0
  linux-headers-4.15.0-58-generi
  Linux kernel headers for version 4.15.0 on 64 bit x86 SMP
  linux-image-4.15.0-58-generic
  Signed kernel image generic
  linux-image-4.15.0-64-generic
  linux-libc-dev
  Linux Kernel Headers for development
  linux-modules-4.15.0-58-generi
  Linux kernel extra modules for version 4.15.0 on 64 bit x86 SMP
  linux-modules-4.15.0-64-generi
  linux-modules-extra-4.15.0-58-
  linux-modules-extra-4.15.0-64-
  locales
  GNU C Library: National Language (locale) data [support]
  login
  system login tools
  logrotate
  Log rotation utility
  lsb-base
  Linux Standard Base init script functionality
  lsb-release
  Linux Standard Base version reporting utility
  lshw
  information about hardware configuration
  lsof
  Utility to list open files
  ltrace
  Tracks runtime library calls in dynamically linked programs
  lvm2
  Linux Logical Volume Manager
  lxc-common
  Linux Containers userspace tools (common tools)
  lxcfs
  FUSE based filesystem for LXC
  lxd
  Container hypervisor based on LXC - daemon
  lxd-client
  Container hypervisor based on LXC - client
  m4
  macro processing language
  make
  utility for directing compilation
  makedev
  creates device files in /dev
  man-db
  on-line manual pager
  manpages
  Manual pages about using a GNU/Linux system
  manpages-dev
  Manual pages about using GNU/Linux for development
  mawk
  a pattern scanning and text processing language
  mdadm
  tool to administer Linux MD arrays (software RAID)
  mesa-common-dev
  Developer documentation for Mesa
  mesa-utils
  Miscellaneous Mesa GL utilities
  mime-support
  MIME files 'mime.types' & 'mailcap', and support programs
  mlocate
  quickly find files on the filesystem based on their name
  mobile-broadband-provider-info
  database of mobile broadband service providers
  modemmanager
  mokutil
  tools for manipulating machine owner keys
  mount
  tools for mounting and manipulating filesystems
  mtools
  Tools for manipulating MSDOS files
  mtr-tiny
  Full screen ncurses traceroute tool
  multiarch-support
  Transitional package to ensure multiarch compatibility
  nano
  small, friendly text editor inspired by Pico
  ncurses-base
  basic terminal type definitions
  ncurses-bin
  terminal-related programs and man pages
  ncurses-term
  additional terminal type definitions
  net-tools
  NET-3 networking toolkit
  netbase
  Basic TCP/IP networking system
  netcat-openbsd
  TCP/IP swiss army knife
  nettle-dev
  low level cryptographic library (development files)
  network-manager
  network management framework (daemon and userspace tools)
  network-manager-gnome
  network management framework (GNOME frontend)
  network-manager-pptp
  network management framework (PPTP plugin core)
  nfs-common
  NFS support files common to client and server
  notification-daemon
  daemon for displaying passive pop-up notifications
  ntfs-3g
  read/write NTFS driver for FUSE
  ntp
  Network Time Protocol daemon and utility programs
  open-iscsi
  iSCSI initiator tools
  open-vm-tools
  Open VMware Tools for virtual machines hosted on VMware (CLI)
  openjdk-8-jre-headless
  OpenJDK Java runtime, using Hotspot JIT (headless)
  openssh-client
  secure shell (SSH) client, for secure access to remote machines
  openssh-server
  secure shell (SSH) server, for secure access from remote machines
  openssh-sftp-server
  secure shell (SSH) sftp server module, for SFTP access from remote machines
  openssl
  Secure Sockets Layer toolkit - cryptographic utility
  os-prober
  utility to detect other OSes on a set of drives
  overlayroot
  use an overlayfs on top of a read-only root filesystem
  p11-kit
  p11-glue utilities
  p11-kit-modules
  p11-glue proxy and trust modules
  parted
  passwd
  change and administer password and group data
  pastebinit
  command-line pastebin client
  patch
  Apply a diff file to an original
  pciutils
  Linux PCI Utilities
  perl
  Larry Wall's Practical Extraction and Report Language
  perl-base
  minimal Perl system
  perl-modules-5.22
  Core Perl modules
  pinentry-gnome3
  GNOME 3 PIN or pass-phrase entry dialog for GnuPG
  pkg-config
  manage compile and link flags for libraries
  plymouth
  boot animation, logger and I/O multiplexer
  plymouth-theme-ubuntu-text
  boot animation, logger and I/O multiplexer - ubuntu text theme
  policykit-1
  framework for managing administrative policies and privileges
  policykit-1-gnome
  GNOME authentication agent for PolicyKit-1
  poppler-data
  encoding data for the poppler PDF rendering library
  popularity-contest
  Vote for your favourite packages automatically
  powermgmt-base
  Common utils and configs for power management
  ppp
  Point-to-Point Protocol (PPP) - daemon
  pptp-linux
  Point-to-Point Tunneling Protocol (PPTP) Client
  procps
  /proc file system utilities
  psmisc
  utilities that use the proc file system
  python
  interactive high-level object-oriented language (default version)
  python-apt-common
  Python interface to libapt-pkg (locales)
  python-crypto
  cryptographic algorithms and protocols for Python
  python-dnspython
  DNS toolkit for Python
  python-ldb
  Python bindings for LDB
  python-minimal
  minimal subset of the Python language (default version)
  python-samba
  Python bindings for Samba
  python-talloc
  hierarchical pool based memory allocator - Python bindings
  python-tdb
  Python bindings for TDB
  python2.7
  Interactive high-level object-oriented language (version 2.7)
  python2.7-dev
  python2.7-minimal
  python3
  python3-apport
  Python 3 library for Apport crash report handling
  python3-apt
  Python 3 interface to libapt-pkg
  python3-chardet
  universal character encoding detector for Python3
  python3-commandnotfound
  Python 3 bindings for command-not-found.
  python3-dbus
  simple interprocess messaging system (Python 3 interface)
  python3-debian
  Python 3 modules to work with Debian-related data formats
  python3-distupgrade
  manage release upgrades
  python3-gdbm
  GNU dbm database support for Python 3.x
  python3-gi
  Python 3 bindings for gobject-introspection libraries
  python3-minimal
  minimal subset of the Python language (default python3 version)
  python3-newt
  NEWT module for Python3
  python3-pkg-resources
  Package Discovery and Resource Access using pkg_resources
  python3-problem-report
  Python 3 library to handle problem reports
  python3-pycurl
  Python bindings to libcurl (Python 3)
  python3-requests
  elegant and simple HTTP library for Python3, built for human beings
  python3-six
  Python 2 and 3 compatibility library (Python 3 interface)
  python3-software-properties
  manage the repositories that you install software from
  python3-systemd
  Python 3 bindings for systemd
  python3-update-manager
  python 3.x module for update-manager
  python3-urllib3
  HTTP library with thread-safe connection pooling for Python3
  python3.5
  Interactive high-level object-oriented language (version 3.5)
  python3.5-minimal
  qt
  Qt 5.6.3 lib filesxport PATH=/opt/Qt5.6.3/5.6.3/gcc_64/bin:$PATH
  qt512
  Qt 5.12.9 lib filesxport PATH=/opt/TekSDK/Qt/5.12.9/bin:$PATH
  qttranslations5-l10n
  translations for Qt 5
  readline-common
  GNU readline and history libraries, common files
  rename
  Perl extension for renaming multiple files
  resolvconf
  name server information handler
  rpcbind
  converts RPC program numbers into universal addresses
  rsync
  fast, versatile, remote (and local) file-copying tool
  rsyslog
  reliable system and kernel logging daemon
  run-one
  run just one instance of a command and its args at a time
  samba
  SMB/CIFS file, print, and login server for Unix
  samba-common
  common files used by both the Samba server and client
  samba-common-bin
  Samba common files used by both the server and the client
  samba-dsdb-modules
  Samba Directory Services Database
  samba-libs
  Samba core libraries
  samba-vfs-modules
  Samba Virtual FileSystem plugins
  sbsigntool
  utility for signing and verifying files for UEFI Secure Boot
  screen
  terminal multiplexer with VT100/ANSI terminal emulation
  secureboot-db
  Secure Boot updates for DB and DBX
  sed
  The GNU sed stream editor
  sensible-utils
  Utilities for sensible alternative selection
  sgml-base
  SGML infrastructure and SGML catalog file support
  shared-mime-info
  XXXXXXXXXXXXXXX shared MIME database and spec
  shim
  boot loader to chain-load signed boot loaders under Secure Boot
  shim-signed
  Secure Boot chain-loading bootloader (Microsoft-signed binary)
  snapd
  Daemon and tooling that enable snap packages
  software-properties-common
  manage the repositories that you install software from (common)
  sosreport
  Set of tools to gather troubleshooting data from a system
  squashfs-tools
  Tool to create and append to squashfs filesystems
  ssh-import-id
  securely retrieve an SSH public key and install it locally
  strace
  System call tracer
  sudo
  Provide limited super user privileges to specific users
  systemd
  systemd-sysv
  system and service manager - SysV links
  sysv-rc
  System-V-like runlevel change mechanism
  sysvinit-utils
  System-V-like utilities
  tar
  GNU version of the tar archiving utility
  tasksel
  tool for selecting tasks for installation on Debian systems
  tasksel-data
  official tasks used for installation of Debian systems
  tcl
  Tool Command Language (default version) - shell
  tcl-expect
  Automates interactive applications (Tcl package)
  tcl8.6
  Tcl (the Tool Command Language) v8.6 - shell
  tcpd
  Wietse Venema's TCP wrapper utilities
  tcpdump
  command-line network traffic analyzer
  tdb-tools
  Trivial Database - bundled binaries
  tekscopefilesys
  Tektronix scope filesystem
  telnet
  basic telnet client
  thermald
  Thermal monitoring and controlling daemon
  time
  GNU time program for measuring CPU resource usage
  tk
  Toolkit for Tcl and X11 (default version) - windowing shell
  tk8.6
  Tk toolkit for Tcl and X11 v8.6 - windowing shell
  tmux
  tomcat7
  tomcat7-admin
  Servlet and JSP engine -- admin web applications
  tomcat7-common
  Servlet and JSP engine -- common files
  tomcat7-user
  Servlet and JSP engine -- tools to create user instances
  tzdata
  time zone and daylight-saving time data
  ubuntu-advantage-tools
  management tools for Ubuntu Advantage
  ubuntu-cloudimage-keyring
  GnuPG keys of the Ubuntu Cloud Image builder
  ubuntu-keyring
  GnuPG keys of the Ubuntu archive
  ubuntu-minimal
  Minimal core of Ubuntu
  ubuntu-mono
  Ubuntu Mono Icon theme
  ubuntu-release-upgrader-core
  ubuntu-standard
  The Ubuntu standard system
  ucf
  Update Configuration File(s): preserve user changes to config files
  udev
  /dev/ and hotplug management daemon
  ufw
  program for managing a Netfilter firewall
  uidmap
  programs to help use subuids
  unattended-upgrades
  automatic installation of security upgrades
  unzip
  De-archiver for .zip files
  update-inetd
  inetd configuration file updater
  update-manager-core
  update-notifier-common
  Files shared between update-notifier and other packages
  ureadahead
  Read required files in advance
  usb-modeswitch
  mode switching tool for controlling "flip flop" USB devices
  usb-modeswitch-data
  mode switching data for usb-modeswitch
  usbutils
  Linux USB utilities
  util-linux
  miscellaneous system utilities
  uuid-runtime
  runtime components for the Universally Unique ID library
  vim
  Vi IMproved - enhanced vi editor
  vim-common
  Vi IMproved - Common files
  vim-runtime
  Vi IMproved - Runtime files
  vim-tiny
  Vi IMproved - enhanced vi editor - compact version
  vlan
  user mode programs to enable VLANs on your ethernet devices
  vnc4server
  Virtual network computing server software
  wget
  retrieves files from the web
  whiptail
  Displays user-friendly dialog boxes from shell scripts
  wireless-regdb
  wireless regulatory database
  wkhtmltopdf
  Command line utilities to convert html to pdf or image using WebKit
  wpasupplicant
  client support for WPA and WPA2 (IEEE 802.11i)
  x11-apps
  X applications
  x11-common
  X Window System (XXXXX) infrastructure
  x11-session-utils
  X session utilities
  x11-utils
  X11 utilities
  x11-xkb-utils
  X11 XKB utilities
  x11-xserver-utils
  X server utilities
  x11proto-core-dev
  X11 core wire protocol and auxiliary headers
  x11proto-fixes-dev
  X11 Fixes extension wire protocol
  x11proto-input-dev
  X11 Input extension wire protocol
  x11proto-kb-dev
  X11 XKB extension wire protocol
  x11proto-randr-dev
  X11 RandR extension wire protocol
  x11proto-render-dev
  X11 Render extension wire protocol
  x11proto-xext-dev
  X11 various extension wire protocol
  x11vnc
  VNC server to allow remote access to an existing X session
  x11vnc-data
  data files for x11vnc
  xauth
  X authentication utility
  xbase-clients
  miscellaneous X clients - metapackage
  xbitmaps
  Base X bitmaps
  xdg-user-dirs
  tool to manage well known user directories
  xfconf
  utilities for managing settings in Xfce
  xfonts-base
  standard fonts for X
  xfonts-encodings
  Encodings for XXXXX fonts
  xfonts-utils
  X Window System font utility programs
  xfsprogs
  Utilities for managing the XFS filesystem
  xfwm4
  window manager of the Xfce project
  xinit
  X server initialisation tool
  xinput
  Runtime configuration and test of XInput devices
  xinput-calibrator
  Generic touchscreen calibration program for XXXXX
  xkb-data
  X Keyboard Extension (XKB) configuration data
  xml-core
  XML infrastructure and XML catalog file support
  xorg-sgml-doctools
  Common tools for building XXXXX SGML documentation
  xrdp
  Remote Desktop Protocol (RDP) server
  xserver-common
  common files used by various X servers
  xserver-xorg-core-hwe-16.04
  Xorg X server - core server
  xserver-xorg-hwe-16.04
  XXXXX X server
  xserver-xorg-input-all-hwe-16.
  XXXXX X server -- input driver metapackage
  xserver-xorg-input-evdev-hwe-1
  XXXXX X server -- evdev input driver
  xserver-xorg-input-synaptics-h
  Synaptics TouchPad driver for XXXXX server
  xserver-xorg-input-wacom-hwe-1
  XXXXX X server -- Wacom input driver
  xserver-xorg-legacy-hwe-16.04
  setuid root Xorg server wrapper
  xserver-xorg-video-all-hwe-16.
  XXXXX X server -- output driver metapackage
  xserver-xorg-video-amdgpu-hwe-
  XXXXX X server -- AMDGPU display driver
  xserver-xorg-video-ati-hwe-16.
  XXXXX X server -- AMD/ATI display driver wrapper
  xserver-xorg-video-fbdev-hwe-1
  XXXXX X server -- fbdev display driver
  xserver-xorg-video-intel-hwe-1
  XXXXX X server -- Intel i8xx, i9xx display driver
  xserver-xorg-video-nouveau-hwe
  XXXXX X server -- Nouveau display driver
  xserver-xorg-video-qxl-hwe-16.
  XXXXX X server -- QXL display driver
  xserver-xorg-video-radeon-hwe-
  XXXXX X server -- AMD/ATI Radeon display driver
  xserver-xorg-video-vesa-hwe-16
  XXXXX X server -- VESA display driver
  xserver-xorg-video-vmware-hwe-
  XXXXX X server -- VMware display driver
  xterm
  X terminal emulator
  xtrans-dev
  X transport library (development files)
  xz-utils
  XZ-format compression utilities
  yad
  tool for creating graphical dialogs from shell scripts
  zenity-common
  Display graphical dialog boxes from shell scripts (common files)
  zerofree
  zero free blocks from ext2, ext3 and ext4 file-systems
  zlib1g
  compression library - runtime
  zlib1g-dev
  compression library - development
  zstd
  fast lossless compression algorithm -- CLI tool
来自:计算机科学 / 软件综合
张静茹
进士 学者 机友 笔友
2010/12/30注册,5天14时前活动
