求助,怎么用html输出csv格式文件
法式油炸薯条2015/10/27软件综合 IP:甘肃
我做的一个网页小工具,想要能输出csv,应该怎么做
来自:计算机科学 / 软件综合
金星凌日
8年8个月前 IP:陕西
794759
要把什么样的数据输出成csv?
法式油炸薯条作者
8年8个月前 IP:甘肃
794760
引用 金星凌日:
要把什么样的数据输出成csv?
逗号分隔值,类似这种感觉
35.7, 1007.98, 0.17578125, 0.9609375, -0.1875
35.7, 1007.98, 0.17578125, 0.97265625, -0.17578125
35.7, 1007.9, 0.17578125, 0.9609375, -0.17578125
35.7, 1007.9, 0.1875, 0.94921875, -0.17578125
35.7, 1007.9, 0.1875, 0.94921875, -0.1640625
35.7, 1007.9, 0.1875, 0.9609375, -0.17578125
35.7, 1007.9, 0.17578125, 0.94921875, -0.140625
35.7, 1007.9, 0.1640625, 0.9609375, -0.15234375
35.7, 1007.84, 0.1640625, 0.9609375, -0.15234375
35.7, 1007.84, 0.1640625, 0.9609375, -0.1640625
35.7, 1007.84, 0.15234375, 0.9609375, -0.15234375
35.7, 1007.84, 0.15234375, 0.94921875, -0.1640625
35.7, 1007.84, 0.1640625, 0.94921875, -0.17578125
35.7, 1007.9, 0.1640625, 0.94921875, -0.17578125
35.7, 1007.9, 0.1640625, 0.984375, -0.17578125
35.7, 1007.78, 0.1640625, 0.97265625, -0.1640625
35.7, 1007.78, 0.17578125, 0.9609375, -0.1640625
35.7, 1007.9, 0.1640625, 0.9609375, -0.17578125
35.7, 1007.87, 0.1640625, 0.97265625, -0.17578125
35.7, 1007.87, 0.17578125, 0.984375, -0.17578125
35.7, 1007.81, 0.17578125, 0.9609375, -0.17578125
35.7, 1007.81, 0.1875, 0.94921875, -0.17578125
35.7, 1007.9, 0.17578125, 0.94921875, -0.17578125
35.7, 1007.81, 0.17578125, 0.9609375, -0.1875
35.7, 1007.81, 0.17578125, 0.94921875, -0.19921875
35.7, 1007.84, 0.17578125, 0.94921875, -0.2109375
35.7, 1007.84, 0.1640625, 0.94921875, -0.19921875
35.7, 1007.87, 0.17578125, 0.9609375, -0.19921875
35.7, 1007.87, 0.1875, 0.94921875, -0.1875
35.7, 1007.84, 0.1640625, 0.94921875, -0.2109375
35.7, 1007.84, 0.15234375, 0.94921875, -0.19921875
35.7, 1007.9, 0.17578125, 0.94921875, -0.1875
35.7, 1007.9, 0.17578125, 0.9609375, -0.19921875
35.7, 1007.93, 0.1875, 0.94921875, -0.19921875
35.7, 1007.93, 0.1640625, 0.94921875, -0.1875
35.7, 1007.84, 0.17578125, 0.94921875, -0.1875
35.7, 1007.9, 0.1875, 0.94921875, -0.2109375
35.7, 1007.87, 0.1875, 0.94921875, -0.22265625
35.7, 1007.87, 0.17578125, 0.9609375, -0.2109375
35.7, 1007.84, 0.1875, 0.94921875, -0.2109375
35.7, 1007.84, 0.17578125, 0.9609375, -0.19921875
35.7, 1007.87, 0.17578125, 0.94921875, -0.1875
35.7, 1007.87, 0.1640625, 0.94921875, -0.1875
35.7, 1007.81, 0.17578125, 0.94921875, -0.1875
35.7, 1007.81, 0.1875, 0.97265625, -0.1875
35.7, 1007.84, 0.1875, 0.9609375, -0.1875
35.7, 1007.84, 0.1875, 0.97265625, -0.1875
35.7, 1007.84, 0.1875, 0.94921875, -0.1875
35.7, 1007.87, 0.1875, 0.9609375, -0.1875
35.7, 1007.87, -0.000732421875, -0.000732421875, -0.000732421875
金星凌日
8年8个月前 IP:陕西
794763
引用 法式油炸薯条:
逗号分隔值,类似这种感觉
35.7,...
我想问的是原数据是什么样的。
法式油炸薯条作者
8年8个月前 IP:甘肃
794765
引用 金星凌日:
我想问的是原数据是什么样的。
原数据是javascript里面的几个数组
csaaa
8年8个月前 IP:浙江
794797
静态html在本地运行保存文件的话需要javascript脚本先获得本地读写的权限,再创建文件,打开文件句柄,想文件中写字符或者流。
如果你 的原始数据要在网页上提交的话,就是在服务器端运行和保存文件,就需要在html中嵌入ajax脚本,向服务器端通讯,否则就需要用js,php,asp,cgi或者其它服务器端解释执行的脚本。
acmilan
8年8个月前 IP:四川
794890
网页上javascript没法直接向硬盘写文件,可以先生成临时csv文件(一般是在服务端,html5可以在本地),然后指导用户下载,也可以输出到文本框<textarea>让用户自己复制。
法式油炸薯条作者
8年7个月前 IP:甘肃
795413
引用 acmilan:
问一下具体怎么操作,比如说一个二维数组怎么输出成csv文件让人下载
法式油炸薯条
2014/08/23注册,3年7个月前活动
