【RF Studio】RF19探空火箭发射记录
93°2010/02/16喷气推进 IP:广东
RF19 was successfully launched on 2010/2/15.
we had a 2.4GHz module and a 433MHz module on it, which sends the video signal and flight data back.
well,
let's check the acc data out:
X:
Y:
Z:
and air speed:
it doesnt matter if you reject me:
U0 = 4.2v
Ut = 4.8v
115kpa / 5v * 4.2v = 96.6
115kpa / 5v * 4.8v = 110.4
presure(H) = 96.6kpa
presure(D) = 110.4kpa
presure(delta) = 13.8kpa = 13800pa
p(air) = 1.3kg/m^3
according to the formula : q = (1/2) pv^2
(1/2)pv^2 = 13800pa
0.65 * v^2 = 13800pa
v^2 = 21230pa
v = 145m/s
so, the rocket was flying at 145m/s.
(dont care about it.)
and some pictures(no introduction to them, never mind.)
+1000  科创币    瞳    2010/02/16 强人
+5000  科创币    我说要有光    2010/02/16 赞扬
+999  科创币    power_rdx    2010/02/16 补全
+2000  科创币    delete    2010/02/16 強烈讚揚
+1  科创币    west_0830    2010/02/16 你的分太多了。。
+2000  科创币    black    2010/02/16 於是我
93° 作者
14年5个月前 IP:未同步
191115
the length of my rocket is 1.5m, so,
according to the formula : a = s/t^2
s = 1.6m,
t = 1/24s
a = 1.6m / 0.0173 = 93 m/s^2
93°作者
14年5个月前 IP:未同步
191121
Engine
this time we were using a metal engine:
14年5个月前 IP:未同步
191124
好啊  羡慕啊  [s:259]  [s:118]  [s:233]  [s:237]  [s:116]
93°作者
14年5个月前 IP:未同步
191127
video from my rocket (just ignore it, damn it !!!!!!!)
93°作者
14年5个月前 IP:未同步
191129
novakon
14年5个月前 IP:未同步
191130
[quote]引用楼主93°于10-02-16 17:12发表的 【RF Studio】RF19探空火箭发射记录 :
[size=3]
we are having a 2.4GHz module and a 433MHz module on it, which sends the video signal and flight data back.
.......[/quote]
if u wanna copy my words down here please change the tense first THX.
novakon
14年5个月前 IP:未同步
191134
于广西象州县宽带发来贺电
这次火箭发射视频背景不错。但是插值产生的锯齿依然存在,请教ing.
93°作者
14年5个月前 IP:未同步
191135
引用第7楼novakon于2010-02-16 17:33发表的  :
sorry ,never mind plz
引用第8楼novakon于2010-02-16 17:38发表的 于广西象州县宽带发来贺电 :
idk
[flash=640,480]XXXXXXXXXXXXXXXXXXXXXXX/XXXXXXXXXp/sid/XMTUyNTA5MDgw/v.swf target="_blank" style="font-size:20px;">点击此处查看视频
クロ
14年5个月前 IP:未同步
191138
我靠
9g的加速度
原來是通過壓力變化來計算速度的額
不考慮風壓對傳感器的影響么
why1gz
14年5个月前 IP:未同步
191150
according to the formula : a = s/t^2?
93°作者
14年5个月前 IP:未同步
191156
引用第11楼why1gz于2010-02-16 17:56发表的  :
没问题吧。。。我考试一直这么算啊
chiataimakra
14年5个月前 IP:未同步
191163
引用第12楼93°于2010-02-16 18:03发表的  :
没问题吧。。。我考试一直这么算啊
什么最好玩?无过于初中化学和高中物理以及大学高数
why1gz
14年5个月前 IP:未同步
191164
s=1/2at^2
93°作者
14年5个月前 IP:未同步
191165
引用第13楼chiataimakra于2010-02-16 18:08发表的  :
问题是,算这个用高中物理就够了吧。。
chiataimakra
14年5个月前 IP:未同步
191166
引用第14楼why1gz于2010-02-16 18:09发表的  :
s=1/2at^2
gj
hentai
14年5个月前 IP:未同步
191168
某人說93強的可怕呢- -
等他上線估計有的看了= =
花落一天
14年5个月前 IP:未同步
191169
[s:92] 开伞药又下多了??
PS:其实我很欣赏那个倒插在那里还在燃烧的镜头............
chiataimakra
14年5个月前 IP:未同步
191170
呃,
s = v零t + 1/2at2.
93°作者
14年5个月前 IP:未同步
191176
原始数据文件
attachment icon data.txt 2.41KB TXT 28次下载
bighead
14年5个月前 IP:未同步
191180
开伞失败了??
唔 可以去参加XX比赛了
93°作者
14年5个月前 IP:未同步
191184
s=1/2at^2
有问题?
好吧是我的错,应该是a=s/T^2,不是t
小哈_abc
14年5个月前 IP:未同步
191193
RF18做什么去了~~~~~
93°作者
14年5个月前 IP:未同步
191196
引用第23楼pisces于2010-02-16 18:41发表的  :
RF18做什么去了~~~~~
“条子你好,条子再见”
小龙
14年5个月前 IP:未同步
191215
陕西人民发来贺电      。
t-600
14年5个月前 IP:未同步
191219
特區香港人民发来贺电
phpskycn
14年5个月前 IP:未同步
191222
中华萌国大陆地区浙江省杭县发来贺电
有本的正面图否
jrcsh
14年5个月前 IP:未同步
191240
推力强大阿  哪个土都喷出来了
有没视平 上传上阿  弟一个放在 YOU哪不安全~~~
jrcsh
14年5个月前 IP:未同步
191241
还有哪电路~~板怎么爆的
马小甲
14年5个月前 IP:未同步
191246
那么传统的燃料。。。。。失望。。。。。
14年5个月前 IP:未同步
191252
请上传航拍录像
还有,是不是开伞失败了。。。
93°作者
14年5个月前 IP:未同步
191254
引用第31楼warmonkey于2010-02-16 20:00发表的  :
请上传航拍录像
还有,是不是开伞失败了。。。
画质太渣,上传会被吐槽。。。
93°作者
14年5个月前 IP:未同步
191262
引用第10楼クロ于2010-02-16 17:42发表的  :
我靠
9g的加速度
原來是通過壓力變化來計算速度的額
不考慮風壓對傳感器的影響么
通过动压来计算的
jrcsh
14年5个月前 IP:未同步
191319
93 同伙~~~~ 还好没吧哪个村理的稻草点着了 哈哈   ~~~
见小朋友 烧过一次 吓得几条村 的 人都跑去 救火
west_0830
14年5个月前 IP:未同步
191322
声音比较有力量。。。-1000分。。。
拔刀斋
14年5个月前 IP:未同步
191342
回 楼主(93°) 的帖子
赞!!!!!
2000分太少了
侧卫007
14年5个月前 IP:未同步
191374
请上传航拍录像+1
power_rdx
14年5个月前 IP:未同步
191377
看样子是开伞失败了
是否有最大飞行高度的计算或测量?
93°作者
14年5个月前 IP:未同步
191381
不敢算。。。怕被吐槽
有爱的话,根据图表算吧。。
93°作者
14年5个月前 IP:未同步
191385
引用第33楼jrcsh于2010-02-16 21:45发表的  :
发射时有小雨 。。。不担心
10班陈大葱22号
14年5个月前 IP:未同步
191386
93,54,52,107---2010/2/15 15:32:45 +08:00
2,61,36,107---2010/2/15 15:32:45 +08:00
1,105,55,108---2010/2/15 15:32:45 +08:00
3,52,41,107---2010/2/15 15:32:45 +08:00
5,55,29,108---2010/2/15 15:32:45 +08:00
11,56,48,113---2010/2/15 15:32:45 +08:00
36,69,34,113---2010/2/15 15:32:45 +08:00
63,75,39,113---2010/2/15 15:32:45 +08:00
77,82,42,113---2010/2/15 15:32:45 +08:00
89,79,1,112---2010/2/15 15:32:45 +08:00
97,108,15,109---2010/2/15 15:32:45 +08:00
101,104,19,105---2010/2/15 15:32:45 +08:00
107,80,26,108---2010/2/15 15:32:45 +08:00
z轴加速度应该是第一排吧...单位是什么?
93°作者
14年5个月前 IP:未同步
191388
引用第40楼10班陈大葱22号于2010-02-16 23:13发表的  :
0xff,
可以根据我之前算出来的93m/s^2来算,1是最大值(Z轴是反过来的。。。囧),也就是93
侧卫007
14年5个月前 IP:未同步
191389
我又不是搞这个的,那图表根本就不认识。。。。
10班陈大葱22号
14年5个月前 IP:未同步
191414
奇怪了 如果用加速度积分的话,火箭速度最高大概才60m/s...
加速度应该不止那么点吧...
我的想法是单片机每间隔1ms或更短读一次z轴加速度,存进EEPROM,火箭下来了以后再读出来,积分就可以得到速度了....
power_rdx
14年5个月前 IP:未同步
191445
引用第38楼93°于2010-02-16 23:06发表的  :
不敢算。。。怕被吐槽
有爱的话,根据图表算吧。。
你就放心的算吧,我只是想了解一下火箭开伞失败的时候从多大的高度落下来会造成图中的损伤
相同的问题我不再吐槽。以前吐槽过了以后就算了
14年5个月前 IP:未同步
191480
求加速度计型号及量程
93°作者
14年5个月前 IP:未同步
191483
引用第45楼warmonkey于2010-02-17 11:27发表的  :
求加速度计型号及量程
x和y轴是freescale的mma7260,量程6G
z轴是freescale的mma3201,量程40G
93°作者
14年5个月前 IP:未同步
191484
说实话不是很满意,期待RF20吧,哇哈哈哈哈
侧卫007
14年5个月前 IP:未同步
191498
视频还是不放么。。。。。。
93°作者
14年5个月前 IP:未同步
191500
引用第48楼侧卫007于2010-02-17 12:11发表的  :
视频还是不放么。。。。。。
渣啊。。。。
lovehongkong
14年5个月前 IP:未同步
191505
我看视频刚起飞的时候差点回力了= =!
为嘛X和Y轴也有那么大波动
93°
2007/04/10注册,6年4个月前活动
