出售滨松CR119光电倍增管
江昕岳2024/02/02跳蚤市场 IP:浙江
出售物:滨松CR119型光电倍增管。
来源:从一台表面污染仪里拆出来的。
成色:窗面干净无瑕,无划痕刮碰,整体成色非常完美(从生产至今一直保护在表面污染仪外壳内)
出售原因:因为表面污染仪的窗被戳了,闪烁体划到了,所以拆出来单独售卖。
参数:Diameter: 76mm, head-on type, photocathode material is bialkali ( Effective photosensitive surface diameter: 70mm, Spectral response range: 300-650nm)。
Specifications:
300-650nm,76mm,head-on PMT
Model
CR119
Spectral response range (nm)
300-650
Peak wavelength (nm)
420
Minimum effective diameter of cathode (mm)
70
Photocathode material
Bialkali
Glass shell material
Borosilicate glass
Dynode structure/Stages
Box-and-grid/8
Cathode luminous sensitivity Min. (μA/lm)
80
Cathode luminous sensitivity Typ. (μA/lm)
110
Cathode blue sensitivity index Min.
Cathode blue sensitivity index Typ.
11.5
Anode luminous sensitivity Min. (A/lm)(1000V)
Anode luminous sensitivity Typ. (A/lm)(1000V)
30
Dark current1) Typ. (nA)(1000V)
Dark current1) Max. (nA)(1000V)
Typical gain
2.73×105
Anode to cathode voltage Max. (VDC)
1500
Rise time Typ. (ns)
Operating ambient temperature (℃)
-30~+50
Note: 1) Dark current is the test value after 30 minutes protected from light;
          Shock: 100g(11ms);Sinusoidal vibration: 10g;
          Model name suffix -C is magnetic shielding product.    (转自滨松官网内,XXXXXXXXXXXXXXXXXXXXXX/site/zh/product/guangdianqijian/duanchuangxingguangdianbeizengguan/XXXXXXXXXXXXXXXXXXXXXXml)
联系方式:邮箱:hzjxywhzs@XXXXXXXXX或15858235995@XXXXXXX。QQ:3062877401。
价格:光电倍增管(800元),CRZ0515高压电源(80元),管座和电缆(50元) IMG_20240202_115702.jpg IMG_20240202_115943.jpg IMG_20240202_115943.jpg IMG_20240202_115958.jpg IMG_20240202_115948.jpg IMG_20240202_120032.jpg IMG_20240202_120040.jpg IMG_20240202_120043.jpg IMG_20240202_115854.jpg IMG_20240202_115655.jpg IMG_20240202_115710.jpg IMG_20240202_115716.jpg IMG_20240202_115718.jpg IMG_20240202_115707.jpg IMG_20240202_115727.jpg IMG_20240202_115702.jpg IMG_20240202_120028_edit_60674427545949.jpg Screenshot_20240202_120448_com.android.chrome.jpg
IMG_20240202_115620.jpg IMG_20240202_115626.jpg IMG_20240202_115633.jpg IMG_20240202_115638.jpg
江昕岳
机友 笔友
2023/06/06注册,13天11时前活动
IP归属地:浙江
作者最新文章
