基于百度的公式
基于numpy等库进行开发
也可以直接下载打包好的程序
但还是推荐复制代码自行编译,代码在最后
以下是介绍
冯·卡门曲线的功用不再赘述,因为百度比我更准确
以下是程序(不更新)
以下是算式
\[\begin{array}{l}
\theta {\rm{ = }}{\cos ^{ - 1}}(1 - \frac{{2x}}{L})\\
y = \frac{R}{{\sqrt \pi }}\sqrt {\theta - \frac{{\sin (2\theta )}}{2} + C{{\sin }^3}\theta }
\end{array}\]
解析
L是长度
R是半径
在之后可能会继续更新
以下是效果图
在显示图标之后命令行窗口弹出的数据即为取样点和计算结果
C = 1/3时的图像-20230909更新
新添功能:自动比较出于目标直径最靠近的点
以下是代码(暂时停止同步,最近一次同步发生在20230910)
import math import numpy as np import matplotlib.pyplot as plt print("冯·卡门曲线计算器——仅供娱乐" "\n版本号0.0.0.dev\n" "LD-Haack C= 0\n" "暂未启用(LV-Haack C= 1/3)\n" "长度最长30单位,宽度无限制,命令行输出即为结果") PLong = 30 + 1#长度为30 #PLong = int(input("长度:")) +1 Xlab = [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30]#取样点,长度 # ROP = 20#末端直径 #ROP = int(input("半径:")) Syssign = 1 Count = 0 XOIP = [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30]#暂时存储数据的容器,取样点有多少它就得有多少 Yout = [0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]#输出点,同上要求 pai = [3.14159265] MODEset = 2# 如果模式设置为2 ,则C=1/3 1则为C=0 while(Syssign): SentPL = 0.00 SentPL = 2*Xlab[Count]/PLong #print(SentPL) XOIP[Count] = 1-SentPL Count += 1 if(Count == PLong): Syssign = 0 Count = 0 ARCX = np.arccos(XOIP) plt.plot(Xlab, ARCX, color='yellow', marker="o") Syssign = 1 while(Syssign): XOIP[Count] = ARCX[Count] * 2 Count += 1 if(Count == PLong): Syssign = 0 Count = 0 XOIP = np.sin(XOIP) Syssign = 1 while(Syssign): XOIP[Count] = XOIP[Count] / 2 Count += 1 if(Count == PLong): Syssign = 0 Count = 0 Syssign = 1 while(Syssign): XOIP[Count] = ARCX[Count] - XOIP[Count] Count += 1 if(Count == PLong): Syssign = 0 Count = 0 #如果情况是C = 0则忽略该段,如果是1/3还需要加一个1/3Sin角度的三次方 Syssign = 1 CSINT = ARCX Count = 3 while(Count >=1): CSINT = np.sin(CSINT) Count -= 1 print(Count) Count = 0 if MODEset == 2: while(Syssign): CSINT[Count] = CSINT[Count]/3 XOIP[Count] = XOIP[Count] + CSINT[Count] Count += 1 if(Count == PLong): Syssign = 0 Count = 0 # XOIP = np.sqrt(XOIP) pai = np.sqrt(pai) Syssign = 1 while(Syssign): Yout[Count] = XOIP[Count] * ROP/pai#注意,这里是根号pai Count += 1 if(Count == PLong): Syssign = 0 Count = 0 Syssign = 1 while(Syssign): print("\n\nX:") print(Xlab[Count]) print("Y:") print(Yout[Count]) Count += 1 if(Count == PLong): Syssign = 0 Count = 0 plt.plot(Xlab, Yout, color='blue', marker="o") #plt.plot(Xlab, out_array2, # color='red', marker="o") plt.title("BLUE:OUTPUT\nyellow:rad") plt.xlabel("X") plt.ylabel("Y") plt.show()
以下是实现临近匹配的,由于属于另一个项目,因而只把部分功能实现到这里
while(Syssign):
print("\n\nX:")
print(Xlab[Count])
print("Y:")
print(Yout[Count])
if Yout[Count] <= FOPC:
ZDsign = 1
if ZDsign == 1:
if Yout[Count] >= FOPC:
ZDsign = 2
print("数据的最近似点已采集")
#由于是最靠近的较大数字,因此用减去较小数字来实现逐步逼近的效果
EPSD = Count
print(EPSD)
Count += 1
if(Count == PLong):
Syssign = 0
Count = 0
可以自行寻找合适的点进行替换(但其实不如自己插入进去)
20230910
[修改于 7个月22天前 - 2023/09/10 01:00:00]
