MOXA ioLogik E1210 MODBUS TCP数字量输入模块
大仙2023/01/31跳蚤市场 IP:江苏
全新,1000元一个
Input/Output Interface
  • Digital Input Channels
    • 16
  • Isolation
    • 3k VDC or 2k Vrms
  • Buttons
    • Reset button
Digital Inputs
  • Connector
    • Screw-fastened Euroblock terminal
  • Counter Frequency
    • 250 Hz
  • Digital Filtering Time Interval
    • Software configurable
  • Dry Contact
    • On: short to GND
      Off: open
  • I/O Mode
    • DI or event counter
  • Points per COM
    • 8 channels
  • Sensor Type
    • Dry contact
      Wet Contact (NPN or PNP)
  • Wet Contact (DI to COM)
    • On: 10 to 30 VDC
      Off: 0 to 3 VDC
Ethernet Interface
  • 10/100BaseT(X) Ports (RJ45 connector)
    • 2, 1 MAC address (Ethernet bypass)
  • Magnetic Isolation Protection
    • 1.5 kV (built-in)
Ethernet Software Features
  • Configuration Options
    • Web Console (HTTP), Windows Utility (ioSearch)
  • Industrial Protocols
    • EtherNet/IP Adapter (Slave), Modbus TCP Server (Slave), Moxa AOPC (Active Tag), MXIO Library
  • Management
    • BOOTP, RESTful API, DHCP Client, HTTP, IPv4, TCP/IP, UDP, SNMPv1 Trap, SNMPv1/v2c
  • MIB
    • Device Settings MIB
  • Security
    • Access control list
LED Interface
  • LED Indicators
    • Power, Ready, Port 1, Port 2
Modbus TCP
  • Functions Supported
    • 1, 2, 3, 4, 5, 6, 15, 16, 23
  • Mode
    • Server
  • Max. No. of Client Connections
    • 10
EtherNet/IP
  • Mode
    • Adapter
  • Max. No. of Scanner Connections
    • 9 (for read-only), 1 (for read/write)
Power Parameters
  • Power Connector
  • No. of Power Inputs
    • 1
  • Input Voltage
    • 12 to 36 VDC
  • Power Consumption
    • 110 mA @ 24 VDC
Physical Characteristics
  • Housing
    • Plastic
  • Dimensions
    • 27.8 x 124 x 84 mm (1.09 x 4.88 x 3.31 in)
  • Weight
    • 200 g (0.44 lb)
  • Installation
    • DIN-rail mounting, Wall mounting
  • Wiring
    • I/O cable, 16 to 26 AWG
      Power cable, 12 to 24 AWG
Environmental Limits
  • Operating Temperature
    • -10 to 60°C (14 to 140°F)
  • Storage Temperature (package included)
    • -40 to 85°C (-40 to 185°F)
  • Ambient Relative Humidity
    • 5 to 95% (non-condensing)
  • Altitude
    • 2000 m
Standards and Certifications
  • EMC
    • EN 55032/24, EN 61000-6-2/-6-4
  • EMI
    • CISPR 32, FCC Part 15B Class A
  • EMS
    • IEC 61000-4-2 ESD: Contact: 4 kV; Air: 8 kV
      IEC 61000-4-3 RS: 80 MHz to 1 GHz: 10 V/m
      IEC 61000-4-4 EFT: Power: 2 kV; Signal: 1 kV
      IEC 61000-4-5 Surge: Power: 2 kV; Signal: 1 kV
      IEC 61000-4-6 CS: 10 V
      IEC 61000-4-8 PFMF
  • Hazardous Locations
    • ATEX, Class I Division 2
  • Safety
    • UL 508
  • Shock
    • IEC 60068-2-27
  • Freefall
    • IEC 60068-2-32
  • Vibration
    • IEC 60068-2-6
Declaration
  • Green Product
    • RoHS, CRoHS, WEEE
MTBF
  • Time
    • 671,345 hrs
  • Standards
    • Telcordia SR332
大仙
2008/05/17注册,3时9分前活动
