求助帖:DIY40kg电子秤遇到的问题
Jav2021/12/22电子技术 IP:河南
我基于stc89c52Rc单片机以hx711做ad转换制作一个40kg的电子秤。由于刚接触单片机不久,不能独立完成整个项目,于是上网各种借鉴。
在csdn上借鉴的代码,在坛子上借鉴以前几位大佬做电子秤留下的经验。一切就绪,给电子秤上电后,按压电子秤无数值变化。如视频所示。恳请各位高手帮忙解决一下。
V11222-221026.mp4 点击下载
来自:电子信息 / 电子技术动手实践:社会实践
Jav 作者
2年5个月前 IP:河南
899721
附完整代码。
#include <reg52.h>
#include <intrins.h>
/*I/O口声明*/
sbit LCD1602_RS = P2^6;
sbit LCD1602_RW = P2^5;
sbit LCD1602_EN = P2^7;
sbit HX711_DOUT = P2^1;
sbit HX711_SCK = P2^0;
sbit key1 = P3^1;
sbit key2 = P3^0;
/*全局变量定义*/
unsigned long Weight_Shiwu = 0;
unsigned long Weight_Maopi = 0;
/*函数声明*/
void Delay(unsigned int n);
void Init_LCD1602();
void LCD1602_write_com(unsigned char com);
void LCD1602_write_word(unsigned char *s);
void LCD1602_write_data(unsigned char dat);
unsigned long HX711_Read(void);
void Keyscan();
void Get_Maopi();
void Get_Weight();
int main()
Init_LCD1602(); //LCD1602初始化
LCD1602_write_com(0x80); //移动光标到第一行首位
LCD1602_write_word(" Dian Zi Cheng! "); //显示 Dian Zi Cheng!
LCD1602_write_com(0x80 + 0x40); //移动光标到第二行首位
LCD1602_write_word("Weight :"), //显示Weight :
Delay(1000); //1s延时
while(1)
Keyscan();
Get_Weight();
LCD1602_write_com(0x80+0x49); //移动光标到第二行第九位
LCD1602_write_data(Weight_Shiwu%10000/1000 + 0X30);
        LCD1602_write_data(Weight_Shiwu%1000/100 + 0X30);
        LCD1602_write_data(Weight_Shiwu%100/10 + 0X30);
        LCD1602_write_data(Weight_Shiwu%10 + 0X30);
LCD1602_write_word(" g");
return 0;
/*称实物重*/
void Get_Weight()
Weight_Shiwu = HX711_Read();
Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/108);
Weight_Shiwu = Weight_Shiwu - Weight_Maopi;
/*延时子函数*/
int i, j;
for(i=0; i<n; i++)
for(j=0; j<110; j++);
/*写指令*/
LCD1602_RS = 0;
Delay(10);
LCD1602_EN = 1;
P0 = com;
Delay(10);
LCD1602_EN = 0;
/*写数据*/
LCD1602_RS = 1;
Delay(10);
P0 = dat;
LCD1602_EN = 1;
Delay(10);
LCD1602_EN = 0;
/*写连续字符(字符串)*/
while(*s>0)
LCD1602_write_data(*s);
s++;
/*初始化LCD1602*/
void Init_LCD1602()
LCD1602_EN = 0;
LCD1602_RW = 0;
LCD1602_write_com(0x38);
LCD1602_write_com(0x0c);
LCD1602_write_com(0x06);
LCD1602_write_com(0x01);
/*获取ad值*/
unsigned long count;
unsigned char i;
  HX711_DOUT = 1;
_nop_();
_nop_();
  HX711_SCK = 0;
  count=0;
  for(i=0; i<24; i++)
  HX711_SCK = 1;
  count = count << 1;
HX711_SCK = 0;
  if(HX711_DOUT)
count++;
  HX711_SCK = 1;
    count = count^0x800000;
_nop_();
_nop_();
HX711_SCK = 0;
return(count);
/*称毛皮重*/
void Get_Maopi()
Weight_Maopi = HX711_Read();
Weight_Maopi = (unsigned int)((float)Weight_Maopi/108);
/*按键扫描*/
void Keyscan()
if(key1 == 0)
Delay(10);
if(key1 == 0){
Get_Maopi();
while(!key1);
if(key2 == 0)
Delay(10);
if(key2 == 0)
Weight_Maopi = 0;
while(!key2);
Jav作者
2年5个月前 IP:河南
899722
内容补充:代码中的去皮功能可正常实现。于是我联系电子秤卖家询问相关问题,可惜卖家是个只卖的主,提供不了其他帮助。晚上查阅相关问题,未能找到。我探索时的断开与电子秤连接的杜邦线,lcd显示屏上的数值“光速变化”。
补充:hx711为绿色板,为提高HX711的输出速率已经按照前人(刘上同学)的经验进行了引脚改动。
m24h
2年5个月前 IP:上海
899726
看了一下代码 hx711 dout不该被赋值 而是应该等待它变低再进行读取
此外读取的时间太快 建议每步之间插入适当延时
评论(3)
ZZJ2019
2年5个月前 IP:广东
899748
给你一个我用过的吧
    unsigned char i;
      HX711_DOUT=1;
    _nop_();
    _nop_();
      HX711_SCK=0;
      count=0;
    EA = 1;
      while(HX711_DOUT);
    EA = 0;
      for(i=0;i<24;i++)
          HX711_SCK=1;
          count=count<<1;
        HX711_SCK=0;
          if(HX711_DOUT)
            count++;
     HX711_SCK=1;
               count=count^0x800000;
    _nop_();
    _nop_();
    HX711_SCK=0;
    return(count);
评论(3)
Jav作者
2年5个月前 IP:河南
899761
我甚至找到卖家用了他们店铺给的代码,结果还是按压电子秤没数值变化。将hx711与电子秤断电后,出现如下现象。
V11223-183804.mp4 点击下载
评论(3)
m24h
2年5个月前 修改于 2年5个月前 IP:上海
899768
引用Jav发表于5楼的内容
我甚至找到卖家用了他们店铺给的代码,结果还是按压电子秤没数值变化。将hx711与电子秤断电后,出现如...
视频看不太准 但是好像你线接到了B通道 代码发送25个时钟应该采的是A通道
。。。。又仔细看了一下 原来接头是4脚的 好像又没接错
