南京某山寨运动控制卡厂家封装的DLL
大仙2017/05/31软件综合 IP:江苏
using System;
using XXXXXXXXX.Ports;
using System.Text;
using XXXXXXXXXreading;
namespace IoRS485
public class IOContrl
private SerialPort sP = new SerialPort();
public string[] SearchPort()
return XXXXXXXXXXXXXtPortNames();
public int Open(string sPortName, string sBandRate)
int result;
try
if (!XXXXXXXXXXOpen)
this.sP.PortName = sPortName;
XXXXXXXXXXudRate = XXXXXXXXXXInt32(sBandRate);
this.sP.WriteTimeout = 500;
XXXXXXXXXXadTimeout = 500;
this.sP.Open();
else
XXXXXXXXXXose();
this.sP.Open();
result = 0;
catch
result = -1;
return result;
public int Close()
int result;
try
if (XXXXXXXXXXOpen)
XXXXXXXXXXose();
result = 0;
catch
result = -1;
return result;
public bool BufClear()
this.sP.DiscardInBuffer();
return true;
public string ReadStr(string cmd)
string text = "@" + cmd + "\r\n";
this.sP.Write(XXXXXXXCharArray(), 0, text.Length);
text = XXXXXXXadPort();
if (text.Length > 0)
return text;
return "1";
public string Reset(int addr)
string text = "@" + XXXXXXXString() + ":Reset\r\n";
return text;
return "1";
public string ReadSN(int addr)
string text = "";
try
text = "@" + XXXXXXXString() + ":*IDN?\r\n";
text = XXXXXXXplace("\n", "");
text = XXXXXXXplace("\r", "");
catch
return text;
return "1";
public int ReadAddr(int addr)
string text = "@" + XXXXXXXString() + ":Addr?\r\n";
return XXXXXXXXXXInt32(text);
return 1;
public string WriteAddr(int addr, int value)
string text = XXXXXXXXXncat(new string[]
XXXXXXXString(),
":Addr ",
XXXXXXXXString(),
"\r\n"
return XXXXXXXplace("\r\n", "");
public string SetBTL(int addr, int value)
XXXXXXXString(),
":BRG ",
XXXXXXXXString(),
"\r\n"
public string MotorRun(int addr, string motorNum, long steps)
if (steps == 0L)
return "0";
XXXXXXXString(),
":Motor:Run:M",
motorNum,
XXXXXXXXString(),
"\r\n"
public string MotorMoveTo(int addr, string motorNum, long steps)
XXXXXXXString(),
":Motor:MoveTo:M",
motorNum,
XXXXXXXXString(),
"\r\n"
public string SetMotorPostion(int addr, string motorNum, long steps)
XXXXXXXString(),
":Motor:Pos:M",
motorNum,
XXXXXXXXString(),
"\r\n"
public string ReadMotorPostion(int addr, string motorNum)
XXXXXXXString(),
":Motor:Pos:M",
motorNum,
"?\r\n"
string oldValue = "P" + motorNum + ":";
text = XXXXXXXplace(oldValue, "");
return XXXXXXXplace("\r", "");
public string MotorHome(int addr, string motorNum)
XXXXXXXString(),
":Motor:Home:M",
motorNum,
"\r\n"
public string SetMotorSpeed(int addr, string motorNum, int speed)
XXXXXXXString(),
":Motor:Speed:M",
motorNum,
XXXXXXXXString(),
"\r\n"
public string SetMotorInvert(int addr, string motorNum, int Invert)
XXXXXXXString(),
":Motor:Invert:M",
motorNum,
XXXXXXXXXString(),
"\r\n"
public string SetMotorSpeedStart(int addr, string motorNum, int value)
XXXXXXXString(),
":Motor:SStart:M",
motorNum,
XXXXXXXXString(),
"\r\n"
public string SetMotorSpeedAdd(int addr, string motorNum, int value)
XXXXXXXString(),
":Motor:SAdd:M",
motorNum,
XXXXXXXXString(),
"\r\n"
public string SetMotorSpeedHome(int addr, string motorNum, int value)
XXXXXXXString(),
":Motor:SHome:M",
motorNum,
XXXXXXXXString(),
"\r\n"
public string MotorSave(int addr)
string text = "@" + XXXXXXXString() + ":Motor:Save\r\n";
public string ReadMotorSpeed(int addr, string motorNum)
XXXXXXXString(),
":Motor:Speed:M",
motorNum,
"?\r\n"
public string ReadMotoRunStatus(int addr)
string text = "@" + XXXXXXXString() + ":Motor:Run?\r\n";
text = XXXXXXXplace("R:", "");
if (text.Length >= 4)
text = text.Substring(0, 4);
return text;
public string ReadMotoRunStatus(int addr, string motorNum)
XXXXXXXString(),
":Motor:Run:M",
motorNum,
"?\r\n"
string oldValue = "R" + XXXXXXXXXXXim() + ":";
public string ReadMotoHomeStatus(int addr, string motorNum)
XXXXXXXString(),
":Motor:Home:M",
motorNum,
"?\r\n"
public string MotoStop(int addr, string motorNum)
string text = "@" + XXXXXXXString() + ":Motor:Stop:All\r\n";
public string SetMotorMotorIntMode(int addr, int value)
if (value > 1 || value < 0)
value = 0;
XXXXXXXString(),
":Program:MINT ",
XXXXXXXXString(),
"\r\n"
public string WriteOut(int addr, int channel, int onoff)
XXXXXXXString(),
":Output:Y",
XXXXXXXXXXString(),
XXXXXXXXString(),
"\r\n"
public string WriteOutDelayOff(int addr, int channel, int delaytime)
XXXXXXXString(),
":OutDly:Y",
XXXXXXXXXXString(),
XXXXXXXXXXXXString(),
"\r\n"
public string RealyOnOff(int addr, int value)
string text = "@" + XXXXXXXString() + ":Output:Y9 ";
text = text + XXXXXXXXString() + "\r\n";
public string ReadOutBit(int addr, int channel)
XXXXXXXString(),
":OutPut:Y",
XXXXXXXXXXString(),
"?\r\n"
public string ReadIn(int addr)
string text = "@" + XXXXXXXString() + ":Input:All?\r\n";
return XXXXXXXplace("X:", "");
public string ReadInBit(int addr, int ch)
XXXXXXXString(),
":Input:X",
XXXXXString(),
"?\r\n"
string oldValue = "X" + XXXXXString() + ":";
public int ReadInBit2(int addr, int port)
string text = XXXXXXXadIn(addr);
if (text.Length < 8)
return -1;
if (text[port - 1] == '1')
return 1;
return 0;
public string ReadCounter(int addr, int channel, out int value)
XXXXXXXString(),
":Count:C",
XXXXXXXXXXString(),
"?\r\n"
if (text.Length >= 1)
value = XXXXXXXXXXInt32(text);
else
value = 0;
return "1";
public string XIntModeSet(int addr, int value)
value = 0;
XXXXXXXString(),
":Program:Int ",
XXXXXXXXString(),
"\r\n"
public string XIntModeRead(int addr, int value)
string text = "@" + XXXXXXXString() + ":Program:Int?\r\n";
public string MotorIntModeSet(int addr, int value)
value = 0;
XXXXXXXString(),
":Program:MInt ",
XXXXXXXXString(),
"\r\n"
public string ReadMotorIntMode(int addr)
string text = "@" + XXXXXXXString() + ":Program:MInt?\r\n";
public string SetX8EStopMode(int addr, int value)
value = 0;
XXXXXXXString(),
":Motor:EStop ",
XXXXXXXXString(),
"\r\n"
public string ReadX8EStopMode(int addr)
string text = "@" + XXXXXXXString() + ":Motor:EStop?\r\n";
public string SetFilter(int addr, int value)
XXXXXXXString(),
":Filter ",
XXXXXXXXString(),
"\r\n"
public string ReadAdc(int addr)
string text = "@" + XXXXXXXString() + ":ADC?\r\n";
public string EditWrite(int addr, int E_addr, int E_value)
XXXXXXXString(),
":Program:Edit:",
E_XXXXXXXString(),
E_XXXXXXXXString(),
"\r\n"
public string EditRead(int addr, int E_addr)
XXXXXXXString(),
":Program:Edit?:",
E_XXXXXXXString(),
"\r\n"
public string ReadStep(int addr)
string text = "@" + XXXXXXXString() + ":Program:Pstep?\r\n";
return XXXXXXXXXXInt32(text).ToString();
return "1";
public int ReadPPStep(int addr)
string text = "@" + XXXXXXXString() + ":Program:PPstep?\r\n";
return -2;
public string SetOrigStep(int addr, int step)
XXXXXXXString(),
":Program:ORIG ",
XXXXXXXString(),
"\r\n"
return "1";
public string SetProgramMode(int addr, int mode)
XXXXXXXString(),
":Program:mode ",
XXXXXXXString(),
"\r\n"
return text;
return "1";
public string PtogramStop(int addr)
string text = "@" + XXXXXXXString() + ":Program:Stop\r\n";
return text;
return "1";
public string Pause(int addr, int value)
string text;
if (value == 0)
text = "@" + XXXXXXXString() + ":Program:Pause 0\r\n";
else
text = "@" + XXXXXXXString() + ":Program:Pause 1\r\n";
return text;
return "1";
public string InputPassWord(int addr, string password)
XXXXXXXString(),
":Compare:",
XXXXXXXXXXXXXXXXXXString(),
password,
"\r\n"
public string SetPassWord(int addr, string password)
XXXXXXXString(),
":LOCPASS:",
password,
"\r\n"
public string ClearPassWord(int addr)
string text = "@" + XXXXXXXString() + ":Clear\r\n";
public string ReadCounterSpeed(int addr)
string text = "@" + XXXXXXXString() + ":Count1?\r\n";
public string ReadRotateDirection(int addr)
string text = "@" + XXXXXXXString() + ":FX?\r\n";
public string readPort()
string text = "";
int num = 0;
string result;
try
do
text += XXXXXXXadPortOnce();
if (text.Substring(text.Length - 1, 1) == "\n")
break;
XXXXXXXXXeep(5);
num++;
while (num <= 20);
result = text;
catch (Exception)
result = text;
return result;
public string readPortOnce()
string str = "";
byte[] array = new byte[XXXXXXXXXXadBufferSize + 1];
int count = XXXXXXXXXXad(array, 0, XXXXXXXXXXadBufferSize);
string @string = XXXXXXXXXXXXXXXXXtString(array, 0, count);
return str + @string;
public static int Asc(string character)
if (character.Length == 1)
ASCIIEncoding aSCIIEncoding = new ASCIIEncoding();
return (int)XXXXXXXXXXXXXXXXtBytes(character)[0];
throw new Exception("Character is not valid.");
来自:计算机科学 / 软件综合
大仙
2008/05/17注册,9时44分前活动
